Cam Timing
Old Aug 13, 2018 | 06:30 AM
Sparra's Avatar
Sparra
Default Cam Timing
Hi there folks it's been a while since I have been on here.We are just rebuilding a 96 motor and was just curious about the cam install before the pushrods and rockers are in. As long as the timing marks on the cams are in line do you just rotate the motor until the flat on the crank is lined up with the line on the cam plate and then proceed with the sprockets making sure there 2 marks are lined up? Is there any other way to tell if you are top dead centre on the compression stroke? Hope this makes sense..
Cheers...
Old Aug 13, 2018 | 01:32 PM
djl's Avatar
djl
Outer sprocket positions at TDC front and rear; assuming inner sprockets are properly aligned. If the dots on the inner sprockets are aligned, timing is done. Top photo is rear cylinder at TDC; rear is referred to as cylinder #1. Below photo is front (#2) cylinder at TDC.
Salmo pass
Engine Mechanical Topics
Mar 21, 2019 02:50 PM
Stump juice 09 ultra
Feb 22, 2016 09:19 AM
DJERWIN
Welcome Area Only
Jul 27, 2012 05:38 AM
geronimo73
EVO
Aug 17, 2009 11:37 PM
67xlch
Exhaust System Topics
Oct 24, 2007 07:37 PM
