Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm getting ready to do my first cam swap and I've watched videos and read a ton on here and for the life of my I haven't found an answer. When I'm putting the cam plate back into the cam chest after swapping cams does the front cylinder need to be at TDC or the rear cylinder? Or does it even matter. I've watched the s&s video multiple times and I'm either missing it or he doesn't say.
Your input would be greatly appreciated. Oh yeah it's a TC96 2009 model.
Thanks
If the cams are correctly timed, i.e., the dots on the inner sprockets aligned, you half way there. You can install the cam plate, doesn't matter where pistons are. Next step is aligning the timing marks on the pinion sprocket and rear cam sprocket; if those are aligned, the rear cylinder will be at TDC. See the attached photo.
