Can't pump Lifter plunger. Replace it?
Old Feb 20, 2016 | 08:57 AM
GoofySB's Avatar
GoofySB
Default Can't pump Lifter plunger. Replace it?
2002 RKC, stock 88" motor, 30,000 miles. Checked my lifters last night. Service manual says to move the plunger with your index finger. I have one that I couldn't move. Put a cut off pushrod in a vice and tried to move the plunger that way. No luck. I have not ridden the bike since about October, but I don't recall any lifter noise. I'm in there doing Cyco shoes and B-148's.
Wondering if this lifter needs replacement or just do all 4? Sort of wondering if it could have got jammed up when I cut the pushrods, but I was careful to be on the base circle.
Old Feb 20, 2016 | 09:43 AM
djl's Avatar
djl
Why not take that lifter apart and check it out? At 30K miles, for another $65 you can install a set of CompCams VThunder 850-1 lifters if replacement becomes the plan.
Old Feb 20, 2016 | 09:56 AM
GoofySB's Avatar
GoofySB
Pretty much have been thinking that myself. JEGS is closer & might have faster shipping on their 850-1's at pretty much the same cost. I've been wondering if the VThunder you mentioned are the same thing (identical)?
Thanks, It Gives me a plan.
Old Feb 20, 2016 | 11:25 AM
GoofySB's Avatar
GoofySB
Took it apart and here's what I found. About 3 shards of a slightly orange material. Possibly translucent bits of tensioner shoe. Looking at wear, there is some in the inside top of the body in one area, like something ran crooked. Next, there is a crater or divot in the top outside of the plunger almost opposite the oil hole, but higher up.
If it not trash, does the orientation of the oil holes (body & plunger) matter when reassembling? Haven't put the clip back in, but seems to work ok now.
Edit:
Figured out that the hole orientation shouldn't matter since the plunger hole is in a wide grove that will capture oil. Getting pretty tired of the energy on this and will probably just buy a set and be done with it and future concerns
Old Feb 22, 2016 | 02:06 PM
GoofySB's Avatar
GoofySB
Anyone know if it would be Ok to use 1 Comp Cams 850 lifter and 3 stock Harley ones in my 2002,stock 88” motor?
With adjustable pushrods, would the adjustment be the same? (Is lifter travel the same?) I’m guessing it would be fine or else stock pushrods could be a problem
Read this about rebuilding lifters after I shot a clip across the shop. (Gave up after 2 ˝ hours of looking around)
http://www.crankshaftcoalition.com/w...lacing_lifters
I had the one lifter with some wear. I’d take its clip and use it for the one I lost and buy the 850. I guess I’m cheap.
Thanks,
Old Feb 22, 2016 | 03:12 PM
tfi racing's Avatar
tfi racing
There's cheap(I am as well),but running mis-matched lifters to save $75 would be a bad idea...
Krazy8s
Jun 10, 2018 02:37 PM
cathardo
Exhaust System Topics
13
Oct 8, 2016 02:44 AM
Mitch Mitchell
Engine Mechanical Topics
Oct 21, 2015 10:02 AM
DHARVE3
Sep 23, 2014 08:41 AM
EriCal
EVO
May 18, 2010 08:13 AM
