Andrews 26N cam end play?
Old Apr 13, 2016 | 10:59 PM
theduroche's Avatar
theduroche
Default Andrews 26N cam end play?
Okay. I'm doing some cam chest upgrades (tensioners, cams, cam plate, oil pump, bearings, lifters) in my 2001 FXDX, and I'm getting conflicting information with regards to end play between the cams and the cam plate:
I'm installing Andrews 26N cams in a 2008 cam plate.
The 2008 Dyna service manual I got here
http://kt-trading.net/mcimport/mc/HD...anual.Dyna.pdf
describes how to eliminate (rear) camshaft endplay.
The Andrews installation guide
http://www.andrewsproducts.com/files...n_chain-01.pdf
mentions that it is very important to maintain a minimum of .008" - .012" endplay between both cams and the cam plate.
As for the front cam: with the .100 shim (as recommended by the manual) between the front cam and the snap ring, you ain't gettin' squat for end play.
Rear cam: since the 34T replacement cam sprocket sticks out past the rear cam, it's not possible to have any end play once you tighten down the sprocket bolt.
The crank sprocket has no shims/is as far in as it will go and I needed the .130" shim to even up the 2 sprockets.
I'm gonna try calling Andrews tomorrow, but I figured I'd get your 2 cents.
Help!
Please and thanks.
SPARKY01
May 22, 2026 07:31 PM
RKRider63
Exhaust System Topics
Mar 5, 2013 05:54 AM
bigdog1949
Dec 9, 2012 06:10 PM
JDB
Aug 7, 2011 01:48 PM
Neil
Oct 3, 2008 06:50 PM
