Cam timing question
Old May 13, 2008 | 11:21 AM
schmeg's Avatar
schmeg
Default Cam timing question
Hello to all,
I'm buildign up the top end on my 95" build and I'm up to the rocker boxes. My question is, when both dots on the cams are facing each other, and the dots on the primary and secondary cam sprockets are facing each other ( yes chain cams) the rear cylinder is at TDC on compression stroke. The cams used are Andrews TW21's, and I'm using stock Harley outer cam sprockets, splined secondary (rear) sprocket. The motor is an 01. The sprockets are shimmed properly. By not using an Andrews outer cam sprocket, I just wanted to be sure this sounds like proper cam timing. Thamks, Jay
streetking1
Jan 22, 2017 02:22 PM
streetking1
Engine Mechanical Topics
Jan 22, 2017 12:17 PM
Dyna7
Jan 6, 2014 12:10 PM
BackRoader
Feb 13, 2011 07:23 AM
harleyman1340
Apr 10, 2010 10:20 PM
