Question for the experts...
Old Jul 31, 2010 | 03:41 PM
jlb0038's Avatar
jlb0038
Default Question for the experts...
I did a cam change and did a bonehead thing. After removing everything and then putting the new cams and camplate back in, I lost track of where I was at on the rear cylinder. I could no longer tell if I was on the compression stroke or power stroke.
So, I brought the rear cylinder to the top and lined up the cams, then rotated and brought the front up. I double checked that the lifters were on the heel of the cam lobes when the cylinders were at TDC on the compression stroke, so everything was installed correctly, except that I could have made the compression stroke the old power stroke and vice versa. I did start the bike and it runs good, no wierd sounds. I did notice it started sooner than usual, but I don't know if I'm just being paranoid.
So is it a big deal if I did do this, even though it seems to run good?????
I checked my diagnostics and there are no codes (not sure if it would show any, anyhow).
Any opinions would be greatly appreciated.
J.B.
Old Jul 31, 2010 | 04:00 PM
cuda67bnl's Avatar
cuda67bnl
Doesn't have to be on compression stroke, as long as the cam is on the base circle when you do the pushrods.
Old Jul 31, 2010 | 04:03 PM
shadylane's Avatar
shadylane
When you put the bike in gear does it go in reverse?
Just kidding, the sprockets will only go on the shafts one way, if the dots lined up then your good to go.
Old Jul 31, 2010 | 04:39 PM
jlb0038's Avatar
jlb0038
Thanks alot for the responses. One less thing to worry about.
J.B.
cycler
Engine Mechanical Topics
11
Jun 6, 2019 04:23 PM
zeus0909
Sep 10, 2012 08:00 PM
mafosa
Sep 7, 2008 11:20 PM
67xlch
Oct 24, 2007 07:37 PM
dph1107
Jul 8, 2007 07:18 PM
