Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Valves don't bend from too much side load unless the rocker end is slipping off the end of the stem.
Thank you Max, but until I get all the parts in front of me I won't really be able to determine whether or not it's on or not.. I just took an estimate or should I say an educated guesstimate of measurements and we'll see what happens.. I shouldn't be too far off though and it would only improve what I have by shortening the valve lengths.. I had way too much protrusion on the exhaust valve..
