Not Starting
Old Apr 20, 2025 | 06:11 PM
LittleRoh's Avatar
LittleRoh
6th Gear
Default Not Starting
I keep my 2022 Tri Glide on a battery tender when I'm home. I took it for a ride today. About 15 minutes after starting a red light, engine light and abs light came on. I arrived at my in-laws about 3 minutes later. Now the trike won't start. The engine and abs light flash. I thought maybe the key fob battery was low. I put in my pin. Still no luck. It turns over, just doesn't catch to start. Any ideas??? Thank you in advance!!!
Old Apr 20, 2025 | 06:30 PM
RollaMo's Avatar
RollaMo
So, the engine cranks over (spins), but won't actually start?
That rules out anything to do with the FOB or security.
If it was the FOB battery or security, the engine would not even attempt to spin when you hit the start button (and you would see the message "Enter PIN" on the odometer screen.
Old Apr 20, 2025 | 09:23 PM
Bass Player's Avatar
Bass Player
Just for the hey of it, check your battery connections.
Old Apr 21, 2025 | 12:18 AM
LittleRoh's Avatar
LittleRoh
6th Gear
I checked the battery connections. They're tight. I tried jumping it, no difference. Still turns but doesn't start. I have 13-14 volts. Don't believe it's the battery or starter.
Old Apr 21, 2025 | 05:48 AM
Rounders's Avatar
Rounders
Pull a plug and see if you got spark. Not both. Easier if you have an old plug and just plug the wire into it and leave the plugs in. Odd to lose spark on such a new bike, but it would be the next step, and cheap to do.
I tired to jump a bike with battery that just failed with a pack, it would not do it. Measure the battery after it has been sitting. 13-14 volts is right after being charged, it should drop to 12.3-12.7.
Old Apr 21, 2025 | 06:01 AM
Jackie Paper's Avatar
Jackie Paper
Make sure it has fuel in it. But . Seriously, check for codes.
That's going to be your clue. Under warranty?
Old Apr 21, 2025 | 06:02 AM
Rounders's Avatar
Rounders
Dont go by the gauge
Old Apr 21, 2025 | 11:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Check for codes.
Old Apr 21, 2025 | 12:05 PM
OrcasGTR's Avatar
OrcasGTR
Crank pin sensor?
Just a guess and a reason I keep a spare in the trunk...
Old Apr 21, 2025 | 12:27 PM
Jackie Paper
Originally Posted by OrcasGTR
Crank pin sensor?
After 5 seconds cranking, there would be a code.
Codes on his bike should be readable on a smart phone with a Bluedriver OB2 ($90) with the adapter plug ($12). Worth it since you will have it for the cages and it explains the codes and spells out order to address issue with multiple codes.
Or thru the dash for free.
