Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So its been awhile and I don't remember when doing oil change do you guy put 3 liters in fire up and check or 3 and a half liters to check as I don't want to deal with over filling it. Thanx
