Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have an opportunity to pick up a 2007 TC 103 touring engine for cheap.
curious to know what max HP and TQ I can get with substantial upgrades to 110
heads done
Cylinders and high compression pistons
Cams
Etc. I know a lot of variables, just curious a ball Park guess.
heads done
Cams
andrews 48 and run it 100 ish hp 110 ish tq. unless you plan on rebuilding plugging welding the crank i wouldnt make it too powerfull.
