Piston cleaning
Old Oct 12, 2013 | 05:01 PM
chaz mcnasty's Avatar
chaz mcnasty
Default Piston cleaning
easy way, non abrasive???
Old Nov 17, 2013 | 09:26 PM
2-Piece's Avatar
2-Piece
In the engine or out?
Either way soak with an over the counter combustion chamber cleaner or Sea-Foam. Carbon/varnish should wipe off.
Old Dec 6, 2013 | 10:30 AM
timberwolfz28's Avatar
timberwolfz28
best thing I've ever found was a can of Aircraft Remover. Doesn't harm aluminum. Cleaned up my 110ci pistons from black to beautiful in an hour or so. You can either spray them or get the gallon can and soak them in a small pan instead. Works like a champ!
rquest
Sep 27, 2017 12:09 PM
blackflame
Apr 9, 2013 03:56 PM
pandol34
Nov 7, 2008 12:32 AM
timberwolfz28
Jul 17, 2008 05:17 PM
Newkid52
May 27, 2005 03:19 PM
