Oil pressure dropping
Old Apr 2, 2014 | 10:52 PM
Chopperjohn1969's Avatar
Chopperjohn1969
Stage II
Default Oil pressure dropping
I have a 12 flhx. Motor is stock except for a PC5 with auto tune kit, rhineharts, and stage 1 kit. When I accelerate from a stop or accelerate after making a turn the oil pressure drops to around 10 psi or less but comes back up when you get up to a steady speed. No light has came on. No abnormal noises going on. Oil level is correct. Bike has almost 18,000 miles and is still under warranty. I've always worked on my own cars, and bikes but have never have seen this problem before. Any suggestions besides take it to the shop?
Old Apr 3, 2014 | 11:12 AM
djl's Avatar
djl
No worries; 10-12psi at hot idle is fine. Should run up to 32-34psi at cruise. Early models would show about 3psi at hot idle, sometimes the oil light would blink on/off at a stop.
Old Apr 3, 2014 | 12:35 PM
Chopperjohn1969
Stage II
Oil pressure is 32+ at all times except under moderate acceleration. That's the only time it drops and then comes right back up.
Old Apr 3, 2014 | 04:16 PM
djl's Avatar
djl
32psi at hot idle is not normal and dropping under acceleration is not normal. Gauge could be faulty; check with a manual guage.
Deaners1969
EVO
57
Apr 27, 2018 08:17 PM
FL-kruzen
Nov 13, 2012 04:50 PM
simpkinst
Jul 9, 2011 04:14 PM
Hiawatha Al
Jun 9, 2009 06:49 AM
turbo54
Oil Archive (no new posts)
Apr 4, 2006 01:08 AM
