Visual Difference Between 88 & 103
Old 07-23-2014, 07:15 PM
PoliceBagging's Avatar
PoliceBagging
PoliceBagging is offline
Default Visual Difference Between 88 & 103
I'm thinking of upgrading my 88ci 70k and I found a guy selling his 103ci for $1600 with 5k.
I feel it is a good deal, but being a new Harley owner I would like to know would I be able to visually tell the differences between the engines?
Old 07-23-2014, 08:04 PM
djl's Avatar
djl
djl is offline
Received 2,049 Likes on 1,509 Posts
Unless the 103" motor is one built on the early 4" stroke 88" platform, that motor is not a direct bolt in; major difference in hooking up with the drive train and motor mounts are completely different from '10 and up IIRC. With enough time and money, I guess you could overcome the installation obstacles; however, you could build a strong running 98" motor for much less in time and money than would be required to install the 103" motor in you early bike. JMHO.
Old 07-23-2014, 08:58 PM
PoliceBagging
Thanks, mine is in my 06 Electra Glide and this is 2011engine.
I'm trying to increase HP on a budget. I went to Kendall Johnson Customs Monday, and all those turbo charged baggers have been in my head ever since.
Old 07-24-2014, 11:07 AM
djl's Avatar
djl
djl is offline
Trust me; you don't want to go the turbo or supercharger route. You will be working on the bike more than you will be riding it. Do some digging and look into the 98" packages offered by Hillside VTwin Performance and other; those two shops are forum sponsors.
If you want to go big and have the money, a 117" build is also an option.
Then there is the S&S crate motor option for a 124". Pick your poisin.
Old 07-24-2014, 05:45 PM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
In 2007, HD changed to a six speed. While doing this, they also changed the crank shaft from a square spline with a nut to hold compensator in place to a fine tooth spline with a bolt holding things in place. If keeping the five speed, you will need to buy a different crank. You will also need to use the five speed oil pan, too, IIRC.
I have been telling folks what DLJ just said... buy a 4 3/8 SE crank (which will have the square splines and nut, rebuild the engine you have, and make it either a 113 or a 117.
BigRichRam02
Engine Mechanical Topics
17
01-13-2022 08:44 AM
Pappy1
01-27-2014 09:04 PM
Fire-Medic
Touring Parts
01-09-2013 04:54 AM
jjkrueg
02-28-2012 11:01 AM
DonnyI
11-05-2007 08:26 PM
Quick Reply: Visual Difference Between 88 & 103
