110 vs. 120st
Old Sep 15, 2015 | 11:31 PM
BigRichRam02's Avatar
BigRichRam02
Stage IV
Default 110 vs. 120st
What is this I hear on the 120St costing less then a 110 motor for replacement?
Old Sep 16, 2015 | 01:22 AM
Next In Line's Avatar
Next In Line
Source?
Old Sep 16, 2015 | 05:44 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'd consider a 124" S&S before either.
Scott
Old Sep 16, 2015 | 06:36 AM
prodrag1320's Avatar
prodrag1320
I 100% agree with scott.with all their problems,i wouldn't even consider a 120R or a 110.either build your existing motor to 124" or just get a crate 124".building your existing motor allows you to,1. save money and 2. build a motor that can be tailored to your riding style exactly
Old Sep 16, 2015 | 06:51 AM
Next In Line
I thought it would cost less to go with a crate 124" over the 124" Hot Set Up Kit - existing motor has to be disassembled, machining (Timken conversion, bore for bigger pistons, cam clearance), reassembled.
Old Sep 16, 2015 | 08:08 AM
grbrown's Avatar
grbrown
Lightbulb
Hi from the UK and welcome to HDF. Stacks of expertise in here on upgrading engines and replacing them. Tell us more - what are you planning? My choice, given the budget, would also be an S&S 124, their LC version sounds just great.
Old Sep 16, 2015 | 09:05 AM
BigRichRam02
Stage IV
The reason behind the Harley moco engines is a dealership blew up my engine on the dyno. They are replacing the engine on there dime I wanted something bigger then a stocker 103. I love power and I'm a aggressive you rider maybe its best I get the smaller 110.
Old Sep 16, 2015 | 09:18 AM
grbrown's Avatar
grbrown
A dealer is unlikely to fit a different brand, such as an S&S, but a bigger H-D one shouldn't be a problem. I assume you'll pick up the difference, but I admit I would chose a 120 over a 110, although check warranty on both of them first. I doubt if a 120 comes with much!
Old Sep 16, 2015 | 02:44 PM
djl's Avatar
djl
If the choice is between a 110" motor and a 120ST, bigger may not be better in terms of quality but a bigger platform to work from if the new motor goes Tango Uniform.
Old Sep 16, 2015 | 02:57 PM
BigRichRam02
Stage IV
Well guys my original 96 bored to a 103 at the beginning of the year shat everything out the bottom of the engine case while a local Harley dealership was doing some fine tuning so I'm getting a new 103 on there checkbook. I opted to cover the 300 dollar difference to get a new 110 put in. I live higher rpm power Harleys leave the light right respectable as is I just want more top power I hate the falling on its face feeling when I get in the triple digits. I drive it daily.
