Primary leak question
You will need some special tools for the job, but even if you buy the tools for the job you will still be able to save some money compared to paying a shop to do it.
The manual will tell you how to :
Remove outer primary cover
Remove primary chain tensioner
Remove the compensator nut (Standard Thread)
Remove the clutch hub nut (Left Hand Thread)
To get access to the clutch hub retaining nut you must remove the snap ring that holds the adjuster plate at the center of the clutch. You don`t have to disassemble the clutch, it can come off as one unit.
The clutch/primary chain/compensator sprocket will all be removed at the same time.
Remove starter jackshaft
Remove starter mount bolts
Remove bolts securing inner primary cover
Remove primary inner cover
Remove pulley nut (Left Hand Thread)
Tools:
A 1-1/2 inch socket to remove the compensator nut. Big breaker bar
A locking device to immoblize the clutch/compensator, several ways to do this, some use a locking bar, some use a wedge between the primary chain and the clutch and primary sprockets.
The nut that holds the clutch hub to the mainshaft is 1-3/16, if my memory is correct
A special socket for the pulley nut must be fabricated or purchaced, 1-7/8 inch.
If you must rremove the mainshaft bearing race you will need a special puller/installer tool.
You can find some of the tools needed on ebay, or georges-garage.com , also jims machining.
The old pulley design uses a single bolt to prevent the pulley nut from backing off.
The new pulley design uses a lockplate and two bolts to keep the nut from backing off, it also used a different pulley and spacer.
If you have the old pulley, throw the pulley,nut, lockbolt and spacer into the scrap pile.
If you already have the new pulley design, keep the pulley if it looks ok but replace the bolts that hold the lockplate, also replace the quad seal that goes under the spacer, and the spacer itself.
Also replace:
Main drive gear seal (the big seal).
Main drive gear/mainshaft seal,it goes between the main drive gear and the mainshaft.
Starter jackshaft seal
Shifter shaft seal
Mainshaft bearing seal on the inner primary
Sorry for such a long winded post, but I`m off today and it is 12 degrees outside...
It's freezing down here, too. I installed a Twin Tec single-fire ignition yesterday with my electric oil heater going full blast and I still nearly froze. If this cold keeps up, I will just deal with the bike after it warms up a bit!
The new configuration uses a lockplate, bolted to the pulley that holds the nut.
It also uses a pulley that is thicker at the center web, and a narrower spacer.
12 degrees is painful for this Southern boy to even think about! It's 44 here and sunny. I just got my bike put back together after installing a new Daytona Twin Tec single-fire ignition/coil/plug wire kit that I got a good price on. The bike seems to like it. It's running very well. I think I might take her out for a spin today or tomorrow!
I should be able to handle this, my garage is unheated so I want to gather everything I'll need so that when I get a warmer weekend I can knock it out.
1 - 40210-8SP Sprocket 'upgrade kit' $75.95
1 - 11147 O-Ring $3.95
1 - 34901-85 Gasket $14.95
1.5 quarts primary oil $6.38
1 pint trans oil $3.50
Shop 'supplies' $2.00
Total Parts $104.73
Labor (remember it's 1996) $85.50
Total Repair $203.76
Here's the parts list from Kissimmee Harley-Davidson to repair the leak a second time (10/21/2002):
1 - 11105 O-Ring $.28
1 - 11147A O-Ring $1.75
1 - 12052 Oil Seal $3.20
1 - 12053A Oil $5.65
1 - 31430-93 Thrust Washer $3.60
Supplies $5.00
Labor (3.5 hours) $210.00
Like I replied, it's not a difficult repair, it's just a PITA repair. If mine ever starts to leak again, I will put the JIMS sprocket and lockplate/nut combo on. They make the HD parts look like the junk they are.
One, you don't know for sure the pulley is loose and/or needs replacement or if the transmission seal is even leaking. It may only be the inner primary seal. There's about 125.00 difference in tools and parts needed between the inner primary job and pulley/seal/spacer portion of the job. And that's not counting a "pulley kit." Midwest (Jireh) sells a "kit" a few dollars less than Revtech and the Midwest kit is junk. The pulley is correct, but it doesn't include a spacer because the included seal is for the older models and will not work with the required spacer for the wider (post '93) pulley. So be careful ordering if you end going that far.
Naturally, anyone who's had a failure in that area is gonna scream (I would) but don't assume the pulley is bad or even loose until you get it apart. Mine had 105,000 when I did the trans and I went back with the original old style thin pulley because it was tight on tear down and the seal was only seeping. I'd done the inner primary seals about 15,000 miles prior and all looked well, so...
Other than the pulley nut, basic hand tools are all that are required for initial teardown/inspection so unless you have bucks to throw around, take my advice and tear it down first...
More likely, it will do like mine did and hit the inner primary. Trust me, when that happens, you'll know it. My bike felt like it was 'missing', in addition to the noise(s). Little did I know, that the inner primary was getting a custom machining job.
You're gonna have to trust me on this, the 'new and improved' version is still prone to loosening up.
Looks like I need to crack it open and find out what's going on. But like someone here said... it IS winter! Might as well break open the clutch and replace the plates, or get a heavier duty clutch, while I'm in there... my bike has about 50,000 miles on it.
Thanks for the very useful info Hackd!
Sorry to hear it, but atleast you know where that slow primary leak is now..just like me. It's 18 degrees in my garage right now so I'm in no hurry, wanna split the cost of the tools.
Doug
Another way to identify the problem, is to clean off the area, get some dye and put it into the transmission. Run it for a few miles, put a black light on the area, and see if it's trans oil.
Again, I would toss the OEM crap into the scap bin and install the JIMS sprocket/lockplate. Good time to do a final gearing change if you want, as JIMS offers a variety of tooth counts.
If you don't want to crawl around on cold concrete: Check with a local indy (My experience: The 'stealers don't like working on old junk - or they don't have any 'old timers' working there.) to see what they might charge to fix it. Someone that's got a lift/hoist, an impact, and knows what they're doing, should be able to 'fix' it in around three hours or less.
