TP engineering 121 install
Old Jun 20, 2014 | 08:58 AM
nyokie's Avatar
nyokie
Default TP engineering 121 install
Got it set in the frame and bolted up last night. Fit like a glove, some how they managed to build it with exact same height as the stock 80. It's on and ready for oil lines and wiring up the new ignition. Then fire up the monster. Ignition has negative wire for front and rear cylinder to coil but my stock coil only has a positive and a single negative, I assume I just tie the two negative trigger wires together?
Old Jun 20, 2014 | 09:02 AM
nyokie's Avatar
nyokie
And a few pics!
Attached Thumbnails TP engineering 121 install-20140619_202036.jpg   TP engineering 121 install-20140619_202106.jpg   TP engineering 121 install-20140619_210447.jpg   TP engineering 121 install-20140619_210439.jpg
Old Jun 20, 2014 | 09:14 AM
92Fatty's Avatar
92Fatty
Nice. I'm no expert but sounds right on the ground wires. Is it a single fire ignition? I've been lusting over more cubes lately myself. That baby is going to running in no time.
Old Jun 20, 2014 | 09:24 AM
nyokie's Avatar
nyokie
Yeah thunder heart single fire ignition but pretty sure you can use with dual fire coil.....maybe wrong might have to buy a coil
Old Jun 20, 2014 | 10:29 AM
Throttle_Jockey's Avatar
Throttle_Jockey
Single fire ignitions have a different OHM coil then dual.
Simone correct me if I'm wrong , but IIRC single fire is 3 ohm dual fire is 5 ohm.
Old Jun 20, 2014 | 10:48 AM
jimbo285's Avatar
jimbo285
You gotta update your signature now.
Old Jun 20, 2014 | 10:51 AM
traildog's Avatar
traildog
Who is Simone?
Old Jun 20, 2014 | 11:01 AM
nyokie's Avatar
nyokie
Engine builder told me to use a 3 ohm with this ignition and as far as I know the stock evoi coil is 3
Old Jun 20, 2014 | 11:42 AM
Throttle_Jockey
Originally Posted by traildog
Who is Simone?
Someone*
What is that " VAROOM " in your sig? Is that sound you make when you sit on your bike with a fan in front of you?
Old Jun 20, 2014 | 11:48 AM
tmanbuckhunter's Avatar
tmanbuckhunter
That's the sound he makes sitting on his bike while someone trailers it around.
