keeping this one
Old Jan 6, 2015 | 03:58 PM
glidein wide's Avatar
glidein wide
Default keeping this one
Picked up a 1986 fxwg ,a while back seriously molested finally gettin it the way I want it.Can't get the belt to stop sweeking, any ideas out there?
Old Jan 6, 2015 | 06:00 PM
misfitJason's Avatar
misfitJason
Improper alignment or worn pulleys/belts
Old Jan 6, 2015 | 06:06 PM
Harleycruiser's Avatar
Harleycruiser
Yep what he said.
Are you using the belt tention tool to measure how tight?
Old Jan 6, 2015 | 06:07 PM
Stiggy's Avatar
Stiggy
Worn belt / pulleys probably. Since I didn't have the cash way back when, a little dab of anti seize on the outer edge of the belt every couple of thousand miles got me another 2 years and 30,000 miles out of it without that irritating squeak..
Old Jan 6, 2015 | 07:15 PM
JohnMB's Avatar
JohnMB
Is it the stock rear pulley?
Old Jan 6, 2015 | 07:37 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default pic's please
It's always nice to see what we're dealin with......
Old Jan 6, 2015 | 08:12 PM
Schex's Avatar
Schex
Spray the edge of the belt all the way around with WD40, repeat if the noise returns.
WD40 conditions rubber, it's a main ingredient in some kart racing tire preps.
Anti-seize sounds messy.
Old Jan 6, 2015 | 08:44 PM
glidein wide
I've tried anti seiz,wd40,belt dressing,Napa lube,it goes away but back in100 miles. Both pulleys are new along with the belt.tried too tight and too loose it only squeels when on throttle.Worst in cold temps.Belt is running true as far as alighnment goes.
Old Jan 6, 2015 | 09:04 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Is that all you have tried or have you tried anything else?
It would have been nice if you had mentioned all that you had already tried in your first post.
That way we wouldn't have told you to do the things you have already done.
I have to agree with you that it is a belt problem since it goes away (however temporary) when you put something on the belt but I had almost the same problem with a transmission main bearing when it was starting to go out.
Just for fun have you checked your wheel bearings?
Oh and welcome to the Forum!!
Old Jan 6, 2015 | 09:22 PM
glidein wide
Thanks,wheel barrings are fine,noise seems to come from the lobes on belt rather than the sides.Could it be because its a gates brand? I thought theg were good.
