A knocking noise from clutch area. Replaced primairy and clutch hub bearings. Finally found when in high gear and moving wheel back and forth and looked like excessive play at compensator moving back and forth. Replace comp spring and then ok,spring heights where the same, started about 90,000+ .
How do you know when a comp sprocket needs to be replaced ? 86 wide glide, also has auto adjustment
I believe there's a few parts that could be worn. The teeth, the spring pack or the fingers that the whole unit moves on itself. Is it apart? Post some pics I did that with mine when it was off to have the experts take a look.
No problem with it, I just want to know what to watch for.
Then stop looking! Your compensator is the same design that has been used for decades and up to the end of the TC88s. They are not known to have any problems. I have replaced my sprocket and chain, but only because the teeth were sharp and the chain showing signs of stretching. They are known to do in excess of 100k miles. Comp problems are a TC96 and later thing, so you can sleep easy at night!
