Supension-Steering Problem
Old Feb 20, 2015 | 08:02 AM
RLH3175's Avatar
RLH3175
Default Supension-Steering Problem
A few weeks ago I went across some railroad tracks that were real rough, it bounced the bike around quite a bit. Since then the low speed steering has gotten bad. At low speeds when you try to make a slight turn, either way, the front wheel/forks, try to go all the way to the stop, you have to fight it. I rode it last night and it has gotten worse, will put it on the rack tomorrow and start checking it out.
What do you guys think, steering head bearings, broke motor mount, or low tire pressure?
Thanks in advance
Old Feb 20, 2015 | 08:47 AM
Prot's Avatar
Prot
Are the fork legs completely parallel to each other.
I experienced what you describe long ago after a minor crash that left my forks somewhat twisted. I loosened the clamps, straightened them, retightened and was good to go.
Old Feb 20, 2015 | 09:06 AM
RLH3175's Avatar
RLH3175
I am going to at least check the steering head bearings, and will check the legs for straightness. The weather will not be good for riding for a few weeks anyway.
Old Feb 20, 2015 | 09:14 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Check it out and you tell us. Never had a Harley over-steer unless something was broke. Surely you know if it's tire pressure. If you don't, you need a new hobby before you get hurt. If the tire was almost flat, I am sure that is exactly what it would do.
Old Feb 20, 2015 | 09:29 AM
RLH3175's Avatar
RLH3175
Your right, I did check the front tire, it was fine, the rear I looked at and felt of, have to take the saddle bag off to get the gauge on it, will do that to night.
Old Feb 20, 2015 | 11:35 AM
grbrown's Avatar
grbrown
Also check your steering bearings and tightness, and rear wheel alignment.
Old Feb 20, 2015 | 03:57 PM
glidein wide's Avatar
glidein wide
Sit on bike and push a foot or two and lock front brake and see if suspension feels different or if something seems to twist at all,look straight down at it,because something is f@#&ed up.
Also, Jack up front wheel off ground and turn front end with the wheel , lock to lock and see how it feels, smooth, ruff ect.apply pressure at full lock,should not twist much at all.
Hope this helps somewhat.
ScottinAZ
May 26, 2017 12:37 PM
JohnnyRebKY
Jun 7, 2014 09:02 AM
roadrunner68
May 10, 2007 01:28 PM
arachman
Sep 4, 2006 06:17 PM
mchaous
May 27, 2005 11:55 AM
