front end shimmy
Old May 21, 2017 | 11:51 AM
ScottinAZ's Avatar
ScottinAZ
Default front end shimmy
I have a bit of a front end shimmy at speeds over 70mph. Not a death wobble per se, but its enough to be disconcerting to me. The wobble was there without a windshield, but is a bit more pronounced with the one I just installed
Windshield is a fork mount, with the mounts centered between the trees, and adjusted full up for wind abatement (if its much lower, the air coming off the windscreen hits me full in the face)
Forks recently serviced with 10w fork oil and new seals, bushings were good
Tire is a 90-90/19 Dungflop HD tire with about 75% life remaining, but no signs of cupping, pressure at 30psi (on bike when purchased)
Headstock bearings are good, and freshly serviced. Adjusted to spec.
Rider is 6'5" and 350#, bike is a 95 XLH1200, mostly stock
My question is what can I do to limit the shimmy? The front end is tight, but the tire is one size undersized. There are balance weights on it, so I assume the balance is relatively close. What I feel is a slight side to side motion in the bars not an out of balance hopping. almost like its hunting for the proper line.
I realize that the windshield is making the problem worse due to the aerodynamic loading added to the forks, but would like to limit this as much as possible. anyone have any ideas for me short of a bigger bike?
Old May 21, 2017 | 01:52 PM
grbrown's Avatar
grbrown
Wink
What can you do? Start by checking the website for your brand of tyres, for the correct pressures, as that 30psi sounds too low for me. In addition I suggest you add an extra couple of psi to both tyres, to help offset your weight.
On such an old bike other things to consider is the condition of your steering bearings, and if they are adjusted correctly. Some handling problems actually start at the rear, so also check your swingarm bearings and wheel bearings on both wheels. If your wheels have wire spokes check them for tightness and that they both run true.
Old May 21, 2017 | 01:58 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
assume nothing , check the balance yourself
Old May 21, 2017 | 02:31 PM
hscic's Avatar
hscic
Shimmy on cars at higher speeds are normally caused by tire balance issues...so inflate to proper pressure (30psi seems rather low) and balance your tires. Address the most common causes first.
Old May 21, 2017 | 02:36 PM
RANGER73's Avatar
RANGER73
First the pressures too low (mine is 38 PSI), is it balanced correctly, does it have spokes?
Old May 21, 2017 | 02:46 PM
ScottinAZ's Avatar
ScottinAZ
ill bump up the pressures, and the wheels are 9 spoke alloys (no adjustment)
Old May 21, 2017 | 06:53 PM
RANGER73's Avatar
RANGER73
Then it's not loose spokes, so air pressure and balance. Do you have wheel weights? Might have thrown one, try Dynabeads or Ride-On.
Old May 21, 2017 | 07:58 PM
cHarley's Avatar
cHarley
There's nothing wrong with the pressure.
The OP has an OEM Dunlop tire and the HD recommended psi spec in the Owners Manual is 30 PSI.
Old May 21, 2017 | 08:19 PM
RANGER73's Avatar
RANGER73
http://www.drivegreen.com/Motorcycle...y_davidson.htm
38-38 front and rear
Old May 21, 2017 | 08:53 PM
txfxstrider's Avatar
txfxstrider
I had a front wheel shimmy at about 50mph on my 48 that was cured by tightening the steering head bearings slightly tighter than listed spec.
