Turn Signal Problem???
Old Mar 7, 2015 | 06:17 PM
cskarns's Avatar
cskarns
Default Turn Signal Problem???
The turn signals on my '88 Ultra flash really slow. What could be the cause of this? I'm sure its something simple but anything electrical baffles me.
Old Mar 7, 2015 | 06:39 PM
bluharley's Avatar
bluharley
Replace your flashers with Badlands ATS-03, you'll be happy you did. It's a single module that will handle the signals and 4-way, and includes an equalizer in case you want to go to LEDs.
Old Mar 7, 2015 | 09:25 PM
Gunslingertom's Avatar
Gunslingertom
I agree with the Badlands flasher module, but I'd like to know if you are trying to run LED's instead of incandescent bulbs with the stock module?
Old Mar 8, 2015 | 06:34 AM
grbrown's Avatar
grbrown
If everything is stock there are a number of possibilities. Poor ground somewhere in the flasher wiring, poor bulb connection in a bulb holder, poor contact in a wiring connector. These 'electrical' problems are often mechanical! They just need chasing down and sorting out.
Old Mar 8, 2015 | 07:45 AM
SeaZund's Avatar
SeaZund
it's possibly something as simple as the flasher itself needs changed. Do the lights flash slow in both turn and hazard modes? They are 2 different flashers. Swapping in LED lamps without adding the load equalizer will usually cause the system to flash extremely faster, not slower.
Old Mar 8, 2015 | 08:46 AM
cskarns's Avatar
cskarns
Everything is stock. All 4 lights flash slow and they also do it with the flashers on. Also, they don't flash very bright. You can tell they are flashing but have to look really close.
Old Mar 8, 2015 | 04:33 PM
Gunslingertom
The reason I ask is because when I tried to install LED's on my '90, they flashed extremely slow. I've heard that some bikes will flash really fast, really slow, or not at all. My friend's '89 flashed really fast. Badlands cured both of ours. But you are running the stock bulbs, so I lean toward a ground issue.
Old Mar 8, 2015 | 05:41 PM
Spanners39's Avatar
Spanners39
Take all your flasher bulbs out, check they are all the same wattage. Usually they be 12V 21/5w, if you have some 12V 23/8w or something like that in the mix it could go slow like you outlined.
Old Mar 8, 2015 | 06:21 PM
pococj's Avatar
pococj
Flash speed on an older bike with a "flasher" depends on 2 things - resistance and capacitance, aka an RC circuit, with a time constant that depends on the values of R and C. The capacitance is set by the flasher unit and it will change some over time. The resistance is essentially the resistance value of the lamps as well as the entire circuit resistance. Bad grounds can increase the system resistance and cause an increased constant.
My '87-'90 Big Twin parts catalog shows only 1 flasher, so it would seem it is used for both turn and emergency. Of course, it is an HD catalog, so there may be an error! If there is only 1 flasher, change it and see if helps. If the flasher contacts are crusty or burnt, the resistance increases and the flash speed slows; can also cause the lights to be dimmer. Also, there are "heavy duty" flashers that are used when adding more lights - think of a car towing a trailer - and they will flash slower than a standard unit.
Old Mar 8, 2015 | 06:45 PM
Dr.Hess's Avatar
Dr.Hess
FLHT's of this vintage (pre smart-module thingie) have two flashers: One for turn and one for emergency. They can slow down for various reasons mentioned above (except the RC thing, they are thermal, not RC controlled). You can replace the flashers with a universal "OK for LED's" module for a few dollars from about any auto parts store. I did that on my bike, which was also flashing slow. I got them at Advance Auto Parts. The flasher you have in there now is an ancient design used in 50's Corvettes, if I recall. Anyway, the flashers are inside the faring by the right fork. The new modules will be a different shape and take a bit of mashing to get in there and maybe some minor connector fiddling. The original one didn't fit the holder either, and none of it is visible. As a bonus, you can change to LED turn signals if you want at a later date without a "load equalizer" resistor when you change out the flashers with what I suggested.
