Upgrading the clutch
Old May 17, 2024 | 07:08 AM
Javieret's Avatar
Javieret
Default Upgrading the clutch
Hi everybody,
I'm having some problems with my clutch. The bike is a 1997 Road King and the problem is that the clutch engages at almost the end of the lever travel. I've adjusted the clutch to a one full turn out and nothing goes better.
I've been thinking about it and I suppose that maybe the clutch plates are worn and they need to be replaced or maybe if it could be any kind of issue with the clutch cable. If I had to replace the clutch plates, which one would you choose? Any opinions?
Thanks a lot,
Old May 17, 2024 | 08:01 AM
RANGER73's Avatar
RANGER73
You're turning it out too far.
1/2-3/4 turn.
Old May 17, 2024 | 08:33 AM
Schex's Avatar
Schex
It's worth replacing the clutch pack to eliminate the spring plate.
Old May 17, 2024 | 08:42 AM
Bubba Zanetti's Avatar
Bubba Zanetti
1 full turn out is too much. 1/2 a turn is all you need.
Old May 17, 2024 | 08:54 AM
Javieret's Avatar
Javieret
I thought that less turns does the clutch engages still later at the hand lever, that's why I've adjusted It to 1 full turn. Am I wrong?
Old May 17, 2024 | 09:33 AM
Tommy C's Avatar
Tommy C
Follow the procedure outlined in the shop manual. Back the cable adjustment off a few turns before you adjust the screw on the clutch pack. Turn the screw in until you feel resistance, then back it out a half turn, and then adjust the cable.
Old May 17, 2024 | 09:57 AM
Bubba Zanetti
This right here^^^. Make sure the cable has plenty of slack, tighten the clutch screw until it just makes slight contact, then back it out 1/2 turn, then adjust the cable until you have just enough slack for a dime to fit between the end of the cable and the clutch perch.
Old May 17, 2024 | 11:27 AM
Dano523's Avatar
Dano523
Just the opposite myself, and without the judder spring plate, clutch becomes more of an on/off switch, and on heaver touring frame bikes, lots of judder when you try to launch the heavier bikes hard without a judder spring plate in play.
So for me, spring plate gets changed every 40K, gives me a change to take a look at the clutch friction plates, and check the clutch basket bearing to see if going south or not (clutch out, rear tire off the ground, trans in gear, then spin the rear tire to spin the inner hub, to make sure outer basket does not start edge dancing in and out as the inner hub is spinning with wheel.
As for not wanting to run the spring plate (aka grenade plate) that if you try to run too long, is going to come apart,
Then can upgrade the upgrade the basket to later style, that uses Belleville spring washer as the judder spring assembly instead.
Newer clutches that did away with the spring plate,
So really, for touring frame bikes, see the extra plate clutch kits as a cop-out, and should have been standard disc amounts, with a better spring plate design like the newer clutches instead.
As for clutch adjustment, 1/2 turn out once bolt will not hold up allen wrench with cable adjusted all the way in, and all is good with the world.
Also, bike level on lift, only fill primary oil (conventional 10-40 motor oil) to here,
If you still have problem, pull the clutch, since will bank that spring plate ($40) is coming apart, and time to replace it. Myself, I change the spring plate about every 30K, since when it does start to come apart (even single rivet coming apart), can kill $400 in parts on the quick side really fast.
And call me old fashion, but with spring plate and organic friction discs, clutch is easy to use since have more lever travel for engagement to lock up, and easy to slip with needed as well. Plus the alto organic discs do not tear up the steel discs like inorganic frictions discs do, so can get at least a second or thirds set of organic friction disc swaps on the oem steel discs, making a clutch rebuild only $60 with new spring plate, and not the $200 that Barnett and others want for their inorganic extra disc clutch kits isntead.
Old May 17, 2024 | 12:18 PM
08xl1200r's Avatar
08xl1200r
https://youtu.be/YM1G4P1SZjo
Another possible fix would be to use the judder spring setup from a XR1200/Buell XB, I did this when I eliminated the spring plate on my Sportster. I first tried replacing it with two steels and a friction plate, the clutch worked OK but made a VERY annoying squeal when taking off in first gear, sounded like a slipping fan belt. The judder spring retrofit fixed that. I don't know for a fact if this would work on a pre-'98 Evo big twin but the clutch plates are the same as a '91+ XL so it probably would. Anyway the parts required are below, along with two extra steel plates which dealers sell individually. I had to order the three judder spring parts....
Old May 17, 2024 | 03:24 PM
Schex's Avatar
Schex
[QUOTE=Dano523;21681861]Just the opposite myself, and without the judder spring plate, clutch becomes more of an on/off switch, and on heaver touring frame bikes, lots of judder when you try to launch the heavier bikes hard without a judder spring plate in play.
Hmm, not in my experience, friction zone is just fine, and no juddering, whatever that is.
'97 was the last year for the spring plate on touring bikes, 98+, there's a steel seat, a narrow conical shaped damper spring steel and a narrow fiber that goes in the clutch first, then the normal stack.
