Ignition coil testing
But the picture you sent is worth a thousand words!!!! When I go to lunch, I'll check it out per your picture.
thanks a bunch for that!
Thanks!
We had someone else with that same kill switch problem recently. A DPO had done a hack wiring job on the terminal block under the seat when one of the connectors broke off. I think that was a softtail. Look for the thread here. And the fact that someone has been hacking up your wiring harness introduces more potential problems. Did you ever check to see if you have +12V at the coil, like I suggested above?
Thanks for all of your input, I sincerely appreciate it.
If only you were in Memphis!
Stealth, I'd leave the plugs out and hit the button and watch for Sparks and while doing that fiddle with the run stop switch. I think you have a loose wire somewhere. I guess you could check it for 12v at the coil doing the same but I like to see the spark
Just one of those things we must all live with. I'm tolerant of the lesser intelligence's mistakes.
LOL
Just like flying, who do you trust Newton or Bernoulli ? Sometime they both work, and sometime they both fail.
Being old and close to dead, I don't have time to troubleshoot an electrical problem. New components is the easier route for me.
LOL
I'm not getting any spark from my coil also. 12v to the center post and the ohm meter reads 12 on the front and rear posts also. White wire in the center goes back to the timing and pink on the front and blue in the rear. Weird.
Dual fire coils also have no ground as the high voltage potential is between both plug wires.
