Compensator ?
Old May 24, 2015 | 07:28 PM
  #31
Big Dave's Avatar
Big Dave
as a note the bike is new to me ( last fall ) it is an ex cop bike with 45,000 miles on it , i have no service records
Dave
Old May 24, 2015 | 08:43 PM
  #32
JohnMB's Avatar
JohnMB
You did put it in third gear? what year and model?
Old May 24, 2015 | 08:44 PM
  #33
Big Dave's Avatar
Big Dave
1998 FLHPI and yes 3rd gear
Dave
Old May 24, 2015 | 08:55 PM
  #34
JohnMB's Avatar
JohnMB
Im sorry I see your picture I too have police RK. If your detent adjustment checks the next time your able to ride before just taking off from a stop try letting clutch out slowly and see if you can duplicate the problem. you are looking for it to make a slight clunk when letting clutch out in low gear. You may have to do this several times because like you said it wont do it everytime. Goodnight I will check with you tomorow
Old May 24, 2015 | 08:58 PM
  #35
Big Dave's Avatar
Big Dave
OK Thanks
Dave
Old May 25, 2015 | 03:49 PM
  #36
JohnMB's Avatar
JohnMB
Hey Dave able to ride your mc any?
Old May 25, 2015 | 04:32 PM
  #37
Big Dave's Avatar
Big Dave
West coast time zone , just got off work
I ride the bike every day so experimenting today it would not do it however dragging the clutch and low throttle there is a definite click at about 3 ft into take off and its there every time but today it did not slip and clunk ?????
Dave
Old May 25, 2015 | 04:42 PM
  #38
glidein wide's Avatar
glidein wide
No one should have to work on memorial day, good luck with bike, curious.
Old May 25, 2015 | 06:41 PM
  #39
Big Dave's Avatar
Big Dave
Since i can hear/feel that clink when I take off I removed the shift rod so I don't get any false readings and i put the bike in 3rd gear and moved the shift arm forward and back , it is NOT centered , looking at the shift arm it moves forward more then back before resistance is felt . it looks possible to get at the adjusting screw but damn its tight . any idea which way to turn the adjuster , In or out ???? book says 1/4 turn each adjustment then test How finicky is this adjustment does a 1/4 turn move it a lot
LOL lots of questions but feel this may be the right track
Dave
Old May 25, 2015 | 08:29 PM
  #40
perki48's Avatar
perki48
It is not a Holiday in every Country!!
