98 Ultra Classic
Just picked up a 98 UC 95th anniversary with 37000 on the clock. This is my third HD (77 iron head and an 02 Duece) but my first evo. It has had stage 2 done to it and is a very clean well maintained scooter. I have been riding a Yamaha Roadstar 1700 for the last 4 years but I just always wanted an EVO. I hope you guys can give me some insight into things I should look for right off the bat that may need to be addressed. I am not afraid to turn wrenches and Im looking forward to tinkering with this sucker. Thanks in advance for any and all info.
It is a very reliable scoot and you will gets lots of miles out of it. Regular maintenance using the service manual will keep her on the road for a long time.
Was the stage 2 done using a newer cam/ ignition or do you know?
My friend here has one and we did SE heads and a different cam in it and it made lots of difference. Then we added in a 113" S&S motor and that really helped a bunch.
Griz
Griz
I'm picking up an evo tonight. First thing I plan on is changing all three fluids so I know it's good an when it will need changed again.
My plan is to make sure the routine maint things are good then ride for a while to see if anything needs attention. I may pick up a set of plugs to run for a while so I can read them in a few hundred miles to "check the tune" of the carb.
Sounds like a good purchase! Is it that gorgeous maroon and gold paintwork - my favourite? Tips? If the PO had it for several years I hope he passed on his service paperwork too, otherwise as langwilliams suggests, replace all fluids, check the dates on the tyres and replace if more than say 5 years old, then ride and enjoy!
