problems when hot
Old May 8, 2007 | 10:00 PM
91fxrs's Avatar
91fxrs
Stage I
Default problems when hot
hey guys new here. i see a lot of good info so maybe i can get some help. got a 91 fxrs with 37,000mido my own wrenchin. has k&n filter, jetted, pipes. problem is when bike gets good and warm (40+mi) its dying out on me. seems to do it when on hwy but last night on back road i kept in in third at about 3000rpms and it did it again. i cleaned carb this winter so i know thats good new fuel line and petcock also. oh yea i bought the bike this winter. im tring to figure out if it is fuel or ignition. it starts by spitin then if you clutch it it will die coast little you can pop clutch and will refire run spit sputter and die if i stop it will idle and i always manage to nurse it home. go out next day around town im good for 30 or so mi. then get on hwy does it again any help would be great. thanks
Old May 8, 2007 | 10:27 PM
HD7585's Avatar
HD7585
Default RE: problems when hot
When your ignition sensor is bad it will become heat sensitive. When it gets hot you will lose all spark.......When it cools, spark will come back. Take off the points cover and heat the sensor with a blow drier while the bike is running..........If the motor craps out, You've found the problem. If your primary case is extremely low on oil .......This heat will transfer to the lower half of your engine and cause the sensor to fail also
Old May 9, 2007 | 02:23 PM
fxstcguy98's Avatar
fxstcguy98
If theignition sensor is good, check your coil. A coil will do that when hot when it's going bad.
Old May 9, 2007 | 03:20 PM
Reckless Kelly's Avatar
Reckless Kelly
91fxrs -
Welcome to the forum. I've got a 91 FXRS also......I ride it to work and back daily (about 40 miles).........and love it. Haven't had any problems yet................ Let me know when/if you have problems............we can collaborate and try to find answers.
Later -
Old May 10, 2007 | 09:23 AM
pjb's Avatar
pjb
I had a similar problem. turned out to be the ignition module. the screaming eagle one is cheaper then the stock replacement.
Old May 10, 2007 | 10:01 AM
Buddy WMC's Avatar
Buddy WMC
pjb,
Been thining about the SE module for my 93 FXLR. Have you really noticed any difference from the stock one and is it really just plug & play? Thanks
Old May 10, 2007 | 01:42 PM
fxstcguy98's Avatar
fxstcguy98
Yes it is plug-n-play, it seems like it really smoothed the engine out, especially in the lower rpm's and at idle. Doesn't hesitate and cough like it used to.
ORIGINAL: olstoney
pjb,
Old May 10, 2007 | 06:14 PM
ANKRA's Avatar
ANKRA
Welcome to the Forum. Here it is helped you to mush guys here are unique.
Old May 10, 2007 | 07:39 PM
Buddy WMC's Avatar
Buddy WMC
Thanks,
Think I'll try one as it's reasonably priced from Zanotti's. Local Indy is trying to sell me a Dyna 2000, any input on it? I really don't think that I need to spend the money to go to single fire.
Old May 11, 2007 | 09:00 AM
pjb's Avatar
pjb
I didn't notice any difference or improvement with the screaming eagle module, except that it worked without cutting off like my bad module was doing. the price was better then the standard replacement. they are plug and play on the newer models, I don't remember the years, but on my 85 I had the get the newer style harness adapter. not hard to do and not very expensive from what I recall.
