oil filter
Old Mar 31, 2016 | 05:54 AM
Dazzauk's Avatar
Dazzauk
Originally Posted by langwilliams
there's an oil an related products sight where they cut filters open an make recommendations on them based on the results an the stock HD filters are a quality filter. Not the best but not the bad either. I stopped using K&N when they moved production to cheap overseas labor. Don't know if quality went down or not I just don't like companies doing that.
thanks chaps, so im taking away from this that the general consensus is to use a high quality mineral oil 20-50
Old Mar 31, 2016 | 06:45 AM
Hackd's Avatar
Hackd
Originally Posted by kp877
Get the K&N with the nut on the end, makes it easier if you have a tight space come removal time. Install too actually. They come in chrome too
This ^^^^ OEM is a real biotch to remove on my FLHS, because of the add-on front mounted oil cooler.
Just make certain you get the one for the EVO and not the TwinCam.
Old Apr 1, 2016 | 05:47 PM
RidemyEVO's Avatar
RidemyEVO
I use the wix filters.
Old Apr 2, 2016 | 12:25 PM
Dazzauk's Avatar
Dazzauk
Thanks for all the replays chaps. Oil change and filter done today as well as new plugs and leads. Just used standard Harley oil filter and 360 oil. It's a mind field otherwise. It's 20 years old always had standard Harley stuff and still going. That speaks volumes.
However bloody hell my dad should have put these 8.8mm spark plug wires on years ago. The starting is so so so much better.
Old Apr 2, 2016 | 02:31 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I'm glad to hear everything is going good for you.
EdGlide
Oil Archive (no new posts)
11
Jun 28, 2007 08:26 PM
