oil filter mount
Old Apr 13, 2016 | 08:18 AM
DeputyLoud's Avatar
DeputyLoud
Originally Posted by grbrown
It's a conventional thread, not lefthand.
You say you were able to access it from above after removing the seat? Wondering if mine would be the same. Our bikes are only a year apart. I remember trying to get at it from behind the tire while it was on a stand. I could not get enough leverage to get it to move either direction. Had a tech at the dealership say the same thing just after I bought it and it had its first service done. I have a super long 1/2" driver extension. Guess I am going to pull my seat and check that out.
Old Apr 13, 2016 | 09:52 AM
grbrown's Avatar
grbrown
I can see mine over the drive belt, from the left side. I have recently installed a much bigger starter, which only just goes in, hence reduces accessibility. But I don't recall having any problems when I last tightened my oil filter housing up.
Old Apr 13, 2016 | 10:43 AM
0maha's Avatar
0maha
Other than on rotating parts where the force of rotation would tend to loosen a bolt, I can't imagine why it would ever be otherwise.
Old Apr 13, 2016 | 11:49 AM
Grog's Avatar
Grog
It is a normal right hand threaded Bolt and yes you have to remove the starter. I don't see any reason to take off the seat at that point. I also cleaned up the ground and positive connections since they come off with the starter I used some silicone grease on the connections as well as the loctite for the threads.
crusinaussie
Oct 1, 2017 08:21 AM
rmharris
EVO
Sep 24, 2015 08:48 AM
cprhed
EVO
Jul 26, 2015 09:53 AM
RidemyEVO
EVO
May 15, 2015 03:59 PM
1/2crazedbikr
EVO
Jan 9, 2013 03:50 PM
