Dyno Update.....
Look at your Zippers crossover circuit chart again, the tuner is looking at the rich mixture right after 2000 rpms and leaning out after 3000, that is the int to main crossover area. His theory is drop the intermediate one to get the AFR's leaner at the beginning of the crossover and raise the main to richen the 3000 area which may get your 13.2-13.5 when blending with the T-jet with the same jet. I think your dyno guy is putting you in the right direction with his recommendations, spiking the T-jet up is going to come in later in the afr's and no help below 4000 rpm's
You have a torque dip when hitting the throttle and usually a pipe causing that but a rich condition is also present right after the dip started, very possible the recommendation intermediate jet change will clean up the torque dip but not all of it. Think if you get some more fuel in the giddy up range those numbers are going to go up, the mid 14 afr's are going to hold it back
Below are the 2 sheets. Same build just different pipes.. What do you guys think?
One other thing I wanted to mention was when we were doing the pulls I was very interested in top speed in 5th gear. The way I had everything figured was that 6th would get me to 169 mph. I think I'm pretty close cause the 5th gear run today did get to 142 mph @6500 rpm... I was very pleased about that. Not that I will ever take it to that level but man I'd bet it would be pretty cool..
I tried the jet swap. went down to a 28 on the intermediate and up to a 70 on the main. I don't like how lean it's running on the intermediate, I can see the accelerator pump nicely but then it goes pretty lean up to 2700 rpm. The AFR goes from 14-16. What I like the least is cruising at 2500 it's very lean up to 17.
Even though it might be a little rich at the beginning of the wide open throttle run i think the .0295 would be better for all around driving.
Any suggestions?
Any suggestions?
Aren't those about the same numbers you were getting this time last year and you were missing 3 hp?
I still have not put my bike on a dyno. I have no idea what the numbers are but it does feel good.
The dip in the beginning of the run, I believe is the characteristics of the LSR pipe. And the only way to get rid of the dip would be get rid of the pipe. I had this issue the last time I had it tuned at Rosa's as well..and even when Scott tuned it up in Munnsville.. He could not tune out the dip either. I believe this pipe is truly for a larger inch motors and high rpm's.
I have a Bassani 2-1 #12121J. I think I'm going to put that on and tune it with the Wego and go from there. I do realize that I'll probably lose on top but honestly how much are we on top.
And yea 92 fatty, i plan on making sure my cruise is where it needs to be...13.6-14.2.
Anyone have ideas or comments about the Bassani?
280/70 sounds like a good start on jetting to me. Throw that Bassani on and post your results. Do both the LSR and the Bassani have 1 3/4 head pipes? I'd always heard 1 5/8 was best until you upped the cubic inches. But I know you have great flow with those heads.
I Will be installing the Bassani again and go from there and eventually Will do a Dyno run again. I won't change anything else.
Time Will tell..
What kind of baffles are in the pipe? Maybe a simple install of lollipops or the use of fiberglass wrap could help?
Although harder to get dialed in just right, a Mikuni carburetor could help, especially with the dip. They typically provide a smoother transition between different rpm ranges and better throttle response, the latter of which is hard to demonstrate on paper.
