push rods
Apr 22, 2016 | 05:30 PM
Quote:
Originally Posted by
Farm Shop
Not sure if anyone else has run across this but when i put s&s quickies in my 86 heritage I had to shorten the inner pushrod tubes.
Where the threaded portion screws into is really big around and it hit my inner tubes.
Just a heads up. Otherwise great pushrods.
How did you shorten your pushrod tubes???
Apr 22, 2016 | 06:18 PM
texashillcountry
I just took some off the bottom of the inner telescoping part with a die grinder and cleaned it up with a reamer.
They were still plenty long enough to function correctly.
I can't remember if it was a half inch or a full inch that I removed....
Apr 22, 2016 | 06:28 PM
Farm Shop
So you took it off the bottom of the top part of the pushrod tube.
Where did you have the adjustment part of the pushrod (bottom or top)?
Apr 22, 2016 | 06:37 PM
texashillcountry
Correct.
And I had the adjusters on the bottom. I'm not sure if they would work the other way around or not?
Apr 22, 2016 | 06:45 PM
Farm Shop
Correct.
I had S&S quickies in my '95 Heritage and didn't have a problem.
Is it possible you had some aftermarket pushrod tubs??
With as low as the adjuster sits I was trying to figure out how you were hitting.
Apr 22, 2016 | 06:49 PM
texashillcountry
The best I can tell they were stock tubes but I'm not the original owner so I can't be sure.
I think I found a forum post of someone else having the same issue but that was some time ago that I put them in.....
Maybe it was just an early evo thing???
Apr 22, 2016 | 06:58 PM
Farm Shop
Same part numbers for an '86 and a '95 Heritage.
I wonder what caused you to have issues where I didn't.
Maybe S&S redesigned their pushrods between when you bought yours and I bought mine.IDK
Apr 23, 2016 | 11:37 AM
Yeah I can't explain it either....
All I know was it was scary firing it up after the cam and lifter swap and hearing all that racket!!
Overlappinglittlepig
Screamin Eagle CVO Models
Oct 1, 2018 03:48 PM
Lunchboxx
Engine Mechanical Topics
21
Dec 12, 2016 09:03 AM
bigheadted
Apr 25, 2015 10:39 PM
rkduq20
Jun 7, 2013 07:00 PM
ragtop5
General Topics/Tech Tips
Jul 14, 2009 09:34 AM
