Help with ? electrical problem?
Old Aug 4, 2016 | 08:24 PM
ConfuciusSay's Avatar
ConfuciusSay
Default Help with ? electrical problem?
Greetings, I introduced myself to the EVO forum a couple of years ago when I bought my 1993 Heritage Softail Classic. Bike currently has just under 18k miles on it. My son has been riding this and has had sporadic problems where he had to be towed twice. Most recent was tonight. We were riding the state parks and I noticed his lights were getting dim. He thought the bike was running out of fuel because it started to sputter and then it just stalled. Tried to start it with the switch and it just clicked. Tried to jump it (slow roll, 2nd gear, popping the clutch). Nothing.
We recently replaced the voltage regulator as this has happened once before where the battery was completely drained on a ride. My son added an amp and speakers. Everything was fine up to this point. Then the battery started draining and lights went dim on rides. EDIT: We have since removed the amp and speakers.
So, being that we have already replaced the voltage regulator, is the next step replacing the stater? I have a service manual and have great mechanical intent, but limited mechanical ability. If it is the stater, is this a job I can tackle at home? Any other suggestions while I'm in there?
This is my son with the bike as we waited for the tow.
Thanks for all your help.
Old Aug 4, 2016 | 08:29 PM
QC's Avatar
QC
Go back and look at the amp and speaker connections. If everything was fine before this stuff was added, well.......
Old Aug 4, 2016 | 08:32 PM
ConfuciusSay
Understood. I edited the original message to indicate that we removed the amp and speakers and the problem still persists. Thanks for bringing that to my attention so I could clarify.
Old Aug 4, 2016 | 08:43 PM
QC's Avatar
QC
Get the battery fully charged to begin with and test the charging system. The most basic is to start the bike and use a volt meter to check to see it is receiving a charge.
I have not used this test that the link I am posting but many have.
https://www.hdforums.com/forum/elect...sting-1-a.html
Old Aug 4, 2016 | 08:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Have the battery load tested, while battery is out clean all battery cable connections, then perform a charging system check.
It is not the starter.
Old Aug 4, 2016 | 09:01 PM
im's Avatar
im
Buy nothing.
Replace nothing.
Charge battery.
Load test battery.
Then check DC voltage at idle and above idle from battery post.
Review AC...yes it will be AC voltage at stator not DC.
Why did you replace a voltage regulator? did you run a test before replacement?
You are describing a non-charging issue, could be as simple as a loose connection.
Or did someone add an amp, radio, lights, heated gear and other items that can tax the system when it is off....hooked directly to battery and forgot to turn something off.
Old Aug 5, 2016 | 06:10 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Yes check your connection at the primary first. You can separate the male butt connector a little with a small screw driver and clean it with contact cleaner. with a volt meter on ac. check the stator output at 2000 rpm. should be between 30-35 volts ac. if not get a new one. The best I've seen and use is the Cycle electric brand... I've tried others, they suck......
Old Aug 5, 2016 | 06:24 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
No your next step is to charge the battery, grab a volt meter and go through this sticky.
https://www.hdforums.com/forum/evo-c...ng-system.html
Guessing and throwing parts at a problem is a very good way to spend a lot more than needed to fix your problem!!!!!!!!!!!
HD_Doobie
Audio Systems
58
May 30, 2018 09:51 PM
Budda109
Audio Systems
14
Jul 27, 2016 07:05 PM
JOW_103
Sep 8, 2015 01:43 PM
sgr60
Audio Systems
18
Feb 25, 2015 11:48 AM
Newharleylover
Audio Systems
Aug 3, 2014 11:42 PM
