Steering stops dimensions
Old Nov 8, 2016 | 04:03 AM
Gabe FXR's Avatar
Gabe FXR
1st Gear
Default Steering stops dimensions
Good morning all, need some advice. I'm rebuilding an 86 FXRP, i'm using a 91 39mm front end. the previous owner of the bike had un ugly springer on it and decided to grind off all the steering stops from the frame. Was wondering if anyone could send me the dimension of the stopper so i can reweld a new one. Thanks
Old Nov 12, 2016 | 02:54 PM
Scootertrash60's Avatar
Scootertrash60
Got a pic?
Old Nov 12, 2016 | 03:44 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
My suggestion is put the bike on a jack then turn the handle bars till you have about 1" of clearance between the forks and the gas tank.
Then you can measure the size of stopper you need.
Then do the same thing on the other side and you should be good.
I hope this helps.
Old Nov 12, 2016 | 05:04 PM
Gabe FXR's Avatar
Gabe FXR
1st Gear
ok thanks for the advise, i'll give it a try
Old Nov 12, 2016 | 08:33 PM
WP50's Avatar
WP50
You'll need to determine what works on that bike.
WP
Opps What THC said
pmccone5
Feb 9, 2012 08:43 AM
Ragnar Danneskjöld
Feb 23, 2011 07:32 PM
2000FXSTS
Jun 9, 2010 07:48 PM
ScoobyD
Ironhead
May 26, 2008 11:08 AM
jswhitex
Ironhead
22
May 30, 2007 01:08 PM
