Leak
Old Nov 11, 2016 | 05:26 PM
Alienwulf's Avatar
Alienwulf
Default Leak
Need a little help/advice from some smarter heads. Motor is from a 1993 FLHS with 47k on the motor. Top end refreshed pistons, rings, rocker base's Ultima. S&S rockers, value guides, push rods, lifters and lifter blocks. Runs strong no idle or shifting problems. Replaced the starter a couple hundred miles ago. Problem now is I have noticed a weep of oil collecting near the primary cover drain and the first bolt to the left. Just a light finger coating not enough to drip yet. Its red which is what I use in the primary have a honey color gear oil in the trans and 20/50 in the motor. Seems to be coming from the area in the picture's under the belt pulley. There appears to be what i thought an O ring but looks more like silicone. Is this one of the Inner Primary bolts under the clutch basket? I know they are self sealing. Is this enough to worry about? or wait until it starts to puddle on the floor. Any thoughts would be helpful.
Attached Thumbnails Leak-20161111_133052.jpg   Leak-20161111_133130.jpg   Leak-20161111_133145.jpg
Old Nov 11, 2016 | 06:15 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Did you change the starter jackshaft seal when you replaced the starter?
Old Nov 11, 2016 | 06:20 PM
Alienwulf's Avatar
Alienwulf
Now that you mention it, I did not replace it. Can I remove the primary cover and replace it with out removing the starter again? Or both needed.. And thaks for your insight.
Old Nov 11, 2016 | 06:52 PM
texashillcountry
Dirt don't hurt
You have to remove the starter at least.
Old Nov 11, 2016 | 07:31 PM
Alienwulf's Avatar
Alienwulf
Got it..thanks will get on it Monday got a ride tomorrow with some fellow veterans.
Scorpio09SG
Jul 24, 2015 03:58 PM
Scorpio09SG
Electrical/Lighting/Alarm
Jun 10, 2015 12:38 PM
bluharley
EVO
Feb 23, 2014 05:54 AM
JustDave71
May 1, 2010 12:26 PM
Beauregard
Jun 7, 2009 03:16 PM
