Stator Plug Install Challenge
Old Feb 24, 2017 | 11:36 AM
ezridermn's Avatar
ezridermn
Default Stator Plug Install Challenge
I'm am putting a new stator in my engine and I can't get the stator plug to slide into the case hole so the voltage regulator can plug into it from the outside. I've WD-40'd the plug and hole. Then forcefully pushed the plug with a pliers but it is still barely in the hole. I don't want to get too rough and damage something in the process.
I would appreciate it if someone would fill me in on how to get it installed without messing things up.
Thanks in advance for your help!
Old Feb 24, 2017 | 11:47 AM
Uncle G.'s Avatar
Uncle G.
Is this an aftermarket or OEM stator you're installing? The last OEM stator I installed, the plug was so loose it took copious quantities of RTV just to keep it from leaking right away.
Old Feb 24, 2017 | 11:58 AM
ezridermn's Avatar
ezridermn
It is an aftermarket one made by Compufire. Thanks.
Old Feb 24, 2017 | 12:16 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Try using a 1/4" extension to shove it into place.
Old Feb 24, 2017 | 12:40 PM
Kabear's Avatar
Kabear
Instead of WD-40 which actually isn't a lubricant, use WD-40 Silicone lubricant.
Be careful because everything it gets on will be slick for a while.
Old Feb 24, 2017 | 05:28 PM
Yankee Dog's Avatar
Yankee Dog
Slather this on the plug...it will slip right in with minimal force...seriously-it works!
http://www.cvs.com/shop/beauty/skin-...prodid-1015638
Old Feb 24, 2017 | 07:39 PM
WP50's Avatar
WP50
I have used some black (rtv) silicone sealer to get them in. It adds a sealer to the plug.
Good luck WP
Old Feb 25, 2017 | 06:24 AM
t150vej's Avatar
t150vej
What year bike?
If you're replacing a 22 amp alternator with a 30 amp setup, you will need to trim the ribs on the stator plug, else you'll never get it thru the hole. And yes, a silicone lube is highly recommended. I've done a lot of them like that.
Take care to not compromise the wires while pushing on the plug.
Old Feb 26, 2017 | 07:29 AM
ezridermn's Avatar
ezridermn
Default Success
I was able to get the stator plug installed on my bike. As suggested I slathered it with glycerin and shoved it in the hole. Still needed to persuade it by using a pliers to wiggle and press it through the hole with some force. But in about 5 minutes or so it was a done deal.
Thanks for the help!
Old Feb 26, 2017 | 10:00 AM
WP50's Avatar
WP50
Good to hear you got it
WP
