Fork Stem Star Nut Adjust
Old Mar 3, 2017 | 07:10 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by RedHogz
The problem with that is...if you have other worn components such as wheel bearings or bushings what you've effectively done is masked the problem by tightening up the steering head. It's kinda like adding a steering stabilizer to a worn pickup truck front axle. it feels better, but did it really solve the issue? Ehh, Just a thought. Hey ya'll, Happy Friday! Time for a brew.
Yes it did.
Neck bearings were only a couple years old at that time and I check my wheel bearings/bushings religiously.
It's been fine ever since (something like 5 years).
Old Mar 3, 2017 | 08:02 PM
misfitJason's Avatar
misfitJason
I make mine tighter then what they recommend too. I have gotten used to what I set them at over the years by now.
Old Mar 4, 2017 | 05:22 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I don't believe the Book is right on this one. There is no expansion to the neck bearings as you would get in axle bearings...
When I initially set it up this way it was with a brand new set of bearings and races, Neck and axle...... never looked back......
Old Mar 4, 2017 | 07:09 AM
texashillcountry
Dirt don't hurt
Neither do I.
Old Mar 4, 2017 | 08:05 AM
WP50's Avatar
WP50
Originally Posted by 0maha
Thanks all. I think what I'm going to do is get the forks/fender/wheel back in place, the try the swing test from there. Hopefully that gets it to "close enough".
This then set as per post #8
" I set it so there is just a very slight resistance (won't fall away on its own) But you can still turn the front end with the slight push of one finger."
I did it this way before I put the fairing back on. Has done fine for me.
It's kinda like setting the preload on wheel brgs on older vehicles.
WP
Old Mar 4, 2017 | 08:37 AM
RedHogz's Avatar
RedHogz
The trick is to lock it up so it binds and pre-loads, then back it off and do your fall away procedure. This adjustment is an art and a science. And giving it a nudge is necessary to get it off center. Remember Newton's first law of physics? "an object will remain at rest or in uniform motion in a straight line unless acted upon by an external force. It may be seen as a statement about inertia, that objects will remain in their state of motion unless a force acts to change the motion". This will explain it all:
www.youtube.com/watch?v=tkplPbd2f60
Old Mar 4, 2017 | 11:27 AM
johnod's Avatar
johnod
What do you tighten that up with?
Old Mar 4, 2017 | 02:07 PM
WP50's Avatar
WP50
There is a wrench made for it.
A punch and hammer with gentle hits does well enough
WP
Old Mar 5, 2017 | 04:47 PM
Architect's Avatar
Architect
I have a very old screw driver I acquired somewhere in life, has about a 10 degree bend in it, fits perfectly like it was made for the job.
vessel
Dec 7, 2018 11:25 AM
harleyglen
Apr 28, 2016 10:19 AM
Turret_plug
Sep 1, 2012 03:54 PM
korey
Feb 11, 2011 09:21 PM
pyro
Nov 16, 2005 12:06 AM
