fork stem nut
Old Dec 5, 2018 | 09:45 PM
vessel's Avatar
vessel
Default fork stem nut
I have a 98 dyna wide glide with 25,000 and decided to lubricate the steering bearings . I dropped the fork down loosening the pinch bolts and lubricating the bearings when i put it back together i noticed that i could not tighten the fork stem nut all the way down only about halfway down on the threads. I took the fork apart thinking that something was binding and put it together again and same issue with the nut. I just cant remember whether this stem nut was like this before i lubricated the bearings or if i am doing something wrong . i have never done this bearing job on the bike before after installing the top bearing in the neck then the dust cap and the adjustable nut then bracket there is just not enough threads on the stem to tighten down the fork stem nut anymore than halfway.
Old Dec 6, 2018 | 05:24 AM
iaminsider's Avatar
iaminsider
Did you put your upper triple tree on? Upper triple tree goes between the adjuster nut and the stem nut.
Old Dec 6, 2018 | 05:32 AM
Kingglide549's Avatar
Kingglide549
Why do people do this the - HARD WAY?
Learn the rope trick for the bottom bearing..
Old Dec 6, 2018 | 07:36 AM
iaminsider's Avatar
iaminsider
Rope trick? Do tell.
Old Dec 6, 2018 | 07:48 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Does this help?
http://partsfinder.onlinemicrofiche....TEERING%20STEM
Old Dec 6, 2018 | 08:08 AM
beanoboy's Avatar
beanoboy
If the part you are talking about is #43 in the above 'Ronnies' diag. then you really have to put some sweat into getting it tight ! I had to use a large pipe wrech to get it down tight...b.
Old Dec 6, 2018 | 11:11 AM
Kingglide549
Rope trick-
One rope tied tightly around lower bearing where grease will come out when purged.
This will force the grease up to the next vacancy when purged.
Old Dec 6, 2018 | 01:45 PM
Blue Bob's Avatar
Blue Bob
I tightened mine finger tight then lightly preloaded with drift punch, assembled top tree and tubes, and started fall away process.
Old Dec 6, 2018 | 04:28 PM
cggorman's Avatar
cggorman
Not sure if the 98 and 99 differ at the trees/neck but mine didn't go together hard at all. Like Blue Bob, just a light tap of the adjuster for preload and simple torque of the stem jam nut.
Something doesn't sound right.
Old Dec 6, 2018 | 08:14 PM
AJ88V's Avatar
AJ88V
I'm with CGG above. Something sounds wrong.
