Fallaway
I did mine recently and found it was really hard to get the bike balanced up on the lift to do it properly. I just tightened to the point I felt the steering was okay. I think it was about hand tight plus one full turn or so. Not really sure. It works fine though, and I've had to 70mph since with no problems.
Just make sure it's not too loose that it is wobbly, and not so tight you can't move it. You may have to feel around with it a little. It's easy to make sure everything is tightened down and not too tight. It will either wobble (too loose) or not move much (too tight). Find a nice sweet spot somewhere in the middle.
You basically raise the front wheel off the ground, face the bars straight ahead and fashion a pointer which is aimed at the center of the front fender. You would then gently tap or push the wheel to the side and make note of where the front end swings freely to the side. You do this in each direction. The total distance between the "fall away" points should be between 1-3". The other manual I have states the following --
in the bore. If they are not, the steering head adjustment
will become loose and adversely affect the vehicles
handling which could result in death or serious injury.
2. Liberally coat the bearing cones (3) with grease. Work
the grease into the rollers.
3. Place lower bearing dust shield (2) over fork stem. Find a
section of pipe having an inside diameter slightly larger
than the outside diameter of the fork stem. Press bearing
cone (3) onto fork stem and bracket (1) using the pipe as
a press on tool.
4. Insert fork stem and bracket (1) through the steering
head. Install bearing cone (3) and dust shield (5) onto
the stem.
5. Install the upper bracket (6) including the handlebar
assembly and loosely install fork stem bolt (9) with
washer (8).
6. Install fork assemblies (13). See INSTALLATION under
2.15 FRONT FORK.
7. Tighten fork stem bolt (9) to 15 ft-lbs (20.4 Nm). Loosen
fork stem bolt, then retighten to 84
8. Tighten the fork stem clamp screw (7).
