recommendedjetsize
Old Apr 8, 2018 | 09:56 AM
coreyj1971's Avatar
coreyj1971
Stage I
Default recommendedjetsize
i have a 2001 stock FLHT. i put samson 3" miter cut slipons on it. part #DS202166.
I have popping on deceleration and too much gas coming out of the carb. it probably needs to be rejetted. What size kit should i use? Couldn't find the info anywhere.
Old Apr 8, 2018 | 10:32 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
What carb are you running?
Old Apr 8, 2018 | 10:40 AM
1997bagger's Avatar
1997bagger
You have a Twin Cam and you are in the Evo section but will be glad to help. Deaccel gurgle out the exhaust is a lean condition, the 01 CV carb usually comes with a 45 low jet and should be ok for just adding slip on's. The CV has a hidden air/fuel mixture screw, adjusting it takes care of issues like yours because it adds fuel in a throttle off and low speed situations. Attached a link if you are not familiar with the CV.
Fuel misting out the carb with the breather off can be common on a Harley if that is what you are referring to. If it is running out with the breather on then you have a problem, filling the exhaust with excess fuel and igniting it on decel which can happen but the above paragraph is more common. Fuel running out of the carb will need a new needle/seat for repair.
https://cv-performance.com/harley_mixture_screw_tuning
Tileman2692
Nov 13, 2016 06:45 PM
mas0n83
Shovelhead
Oct 14, 2013 05:01 AM
tasker26
Exhaust System Topics
Mar 22, 2012 07:48 PM
Scarletthehog
Ironhead
Jul 2, 2007 01:25 PM
f6noob
Apr 20, 2007 02:32 AM
