Silencer mounting bracket...
Old May 28, 2018 | 08:08 AM
Racepres's Avatar
Racepres
^^ Never seen a Bracket like above... but.. it looks OK
To Clarify.. even if Non-Stock.. hang Front pipe at Engine [easiest] hang rear pipe to tranny someplace.. Find a Way to tie the two headpipes together... the Crossover [if you have one] will thank you... Finally Unless your Mufflers are Very Light weight.. Attach one to the other at the Mufflers.
A Strap is Not good, as they Flex... the Tubular "Strap" is far more Rigid.
Something I was Taught many Moons Ago... You should be able to Lift your bike by the Exhaust System... Good way to approach these.
Old May 28, 2018 | 09:04 AM
Daedalus's Avatar
Daedalus
Yeah, I mounted it, and it stops the ability for both cans to resonate individually, they now resonate as a pack. So after all it makes sense, they are supporting each other now in a way.
ZachGrove1
Aug 7, 2019 10:15 PM
jakson200369
May 30, 2016 02:30 PM
John_K
Feb 18, 2015 05:21 PM
hall1836
Jan 29, 2013 05:13 PM
Walter K
Sportster Parts
Jul 11, 2012 07:45 PM
