Dynatek 2000 install tips
Old May 24, 2018 | 05:26 PM
Mchad's Avatar
Mchad
Default Dynatek 2000 install tips
Because I can’t leave well enough alone, I picked up a 8-pin Dynatek 2000 HD1E8P for my ‘99 FXR2. I thought I had to run one cable to the coil for the tach signal, but the instructions say that’s only necessary for single fire setups. I’m going to leave it as dual fire for now. Ordered a SE coil and wires from Boardtracker, but they won’t be here for a few more days. I’ll start with 6000rpm rev limit and curve 2.
Are there any other tips or things to look out for? Seems like there’s not much for me to screw up...
Old May 25, 2018 | 06:14 AM
flhchaz's Avatar
flhchaz
If it is 8 pin, should be plug and play...
Old May 25, 2018 | 06:27 AM
Mchad's Avatar
Mchad
That’s what I wanted to hear. Thanks.
Old May 27, 2018 | 08:53 PM
Mchad's Avatar
Mchad
Installed it today. Would have taken 5 min, if the genius who designed the OEM module left enough room around the 3/8 nut holding it, for me to get a damn socket on it, instead of making me dick around with it for 20 min before finally getting a thin needle nose on it... Thankfully the Dynatek does allow enough room to get a socket on it.
Anyway, I fired it up an it initially ran like ****. So I checked the switches and saw I had it set for single fire instead of dual fire. After beating myself about the head and face with a wrench, and setting it correctly, it started right up. It was crap weather so I only went a couple of miles, but it ran great. I can’t make a judgement until I get some time on it though.
I have a SE coil and wires arriving Tues. I’ll see if this did anything when I put it on a Dyno on Thurs.
Old May 28, 2018 | 06:56 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Make sure the new plug wires are not actual steel wires. These modules require the carbon core wires... Others can create signal interference..
Old May 28, 2018 | 07:41 AM
Mchad's Avatar
Mchad
Thanks. They are OE HD Screamin Eagle wires. I don't see any docs/description on them on the HD website. Hopefully in the docs that should come with them...
Actually, here's the description, sounds like they are ok:
"These custom 8mm terminated plug wire sets are larger in diameter than stock wires and feature silicone plug boots and suppression core so that your electronic ignition is not affected. Use with your stock production coil or the perfect addition when upgrading to one of our Performance Coils."
Old May 28, 2018 | 12:15 PM
98hotrodfatboy
Perfect..... Ride on.....
Old May 28, 2018 | 03:53 PM
Yankee Dog's Avatar
Yankee Dog
I almost warned you about the single fire vs. dual fire switch....had the same thing happen to me, I guess I should have warned you. Glad you got it all figured out. YD
Old May 28, 2018 | 04:06 PM
user 47363638's Avatar
user 47363638
What’s the noticeable difference with the new ignition
Old May 28, 2018 | 08:07 PM
Tommy C's Avatar
Tommy C
Adjustable rev limiter & advance curves, single or dual fire options, & the timing LED makes it very easy to set the timing.
1981 suprglide
Shovelhead
Feb 7, 2019 07:36 PM
Dudepants
Jan 11, 2019 01:25 PM
txphatboy
Jul 29, 2018 10:27 PM
Tileman2692
May 9, 2018 09:05 AM
