Pulley alignment
08-20-2018, 07:50 AM
Pulley alignment
Hey guys, I've got a question regarding front to rear pulley alignment. I just rebuilt trans in my 86 FLT, new bearings and main shaft gear,replaced front pulley and ran a straight edge on the outside of the pulleys and came up with about a 1/8 -3/16 difference with the front pulley being inboard. is this normal or is something out of whack? I did pull that main shaft gear tight to the main bearing in the case. Any thoughts.Thanks
08-20-2018, 12:24 PM
Do you have the correct sprocket spacer....33334-85?
The newer 33344-94 spacer is not as wide.
08-20-2018, 02:25 PM
Quote:
Originally Posted by
Tom84FXST
Yes, it came with the updated version which is a little narrower .
08-20-2018, 03:18 PM
86glider
Which is not the one you want...you need the wider one...then your pulleys will be aligned
08-21-2018, 07:01 PM
1/8 is such a small amount.
what would be the consequence if it stayed?
08-21-2018, 07:07 PM
splattttttt
If the front pulley is a little wider allowing belt float none, a close fit width wise it'll start eating the side of the belt.
08-21-2018, 07:19 PM
I was expecting the belt would self adjust usin the wider if the twi pulleys as a guide
08-22-2018, 06:34 AM
splattttttt
That doesn't happen if the trans pulley is too far in...no where for it to go in the rear pulley.
08-22-2018, 06:37 AM
Got that!
If it was the other way then yest (;
RidemyEVO
EVO
03-30-2015 09:35 AM
John1957
09-17-2013 10:55 PM
Jumpman
08-23-2013 03:29 AM
lagunatic
08-11-2010 02:28 AM
ozzie65
01-23-2009 03:15 PM
