Engine noise help
Old Sep 4, 2018 | 07:18 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Can't open the link.... What lifters, pushrods and how deep did you set the preload......
Old Sep 5, 2018 | 04:54 AM
Hey Man's Avatar
Hey Man
Noises can be decieving. What I thought might be valve train clatter at certain rpm's turned out to be a vibration from my brake pedal.
Old Sep 5, 2018 | 06:13 AM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by 800screws
That was after I just started it. Choke was on some. I keep it at about 1000 rpm
You definitely do not need to concern yourself with a little start up noises. If the valve sits open, spring pressure bleeds off lifters.. So depending on last stop and how long it sits, you can get some valve noise and piston slap till heat and oil pressure builds. Everything still has oil film, so nothing gets hurt.
Old Sep 5, 2018 | 01:10 PM
800screws's Avatar
800screws
Better
Old Sep 5, 2018 | 03:22 PM
Uncle G.'s Avatar
Uncle G.
I second that. Over the years I’ve chased “engine” noise that turned out to be:
rattling gas caps
rattling brake pedal
rattling footboard
a broken oil tank mount that allowed the oil tank to vibrate against the frame
and most recently, vibrating shift linkage.
Like I’ve said, my bike’s favorite game is called, “guess what THIS noise is, Uncle G.”
Old Sep 5, 2018 | 04:26 PM
Beemervet's Avatar
Beemervet
AHA! It's the LTR-RTL timing cover!
Old Sep 5, 2018 | 09:00 PM
Son of PMS's Avatar
Son of PMS
now that’s funny right there!😂
Old Sep 6, 2018 | 09:57 AM
800screws's Avatar
800screws
Just for the record it came on the bike! lol. It’s got the mirrors too!!! Hahaha!
Old Oct 10, 2022 | 09:50 PM
Longshot1's Avatar
Longshot1
Stage II
Default Emmm
Better
man...regardless, I hear that solid tick, and it sure sounds a LOT MORE than a little valve tick.
Old Oct 11, 2022 | 08:49 AM
cycleman11's Avatar
cycleman11
Use a stethoscope or long screwdriver to try and isolate exactly where the noise is coming from, If the noise changes with the oil pressure changes that is a pretty good clue, but still could be lifters or pump. You likely will have to take the cam chest cover off and have a look.
