Kickstart kit problem
Old Jan 14, 2019 | 05:37 AM
Stevo1340's Avatar
Stevo1340
Default Kickstart kit problem
I have a chrome specialities kicker kit on a sputhe 5 speed kicker only , 1340 evo
the kickstart spins out when I have all my weight on it, landing my in A&E with an over extended knee
it seems to jump off a cog or something and drops out
does anyone have any experience of this kit and what I can do to stop it happening?
people say that’s just normal but it means I can’t rely on it not bustin my leg every time I wanna go for a ride
help very much appreciated
stevo
Old Jan 14, 2019 | 05:57 AM
grbrown's Avatar
grbrown
Stevo, hi from a couple of Counties away. I don't have any experience of either your trans or kicker kit, but have owned a kickstart Harley for many years. There is a bronze bushing in the kicker mechanism which, if it comes loose and moves, can prevent the two halves of the kicker engagement dogs from fully engaging. I haven't suffered any injury, but have had a similar experience as you on a '74 FX1200.
Old Jan 14, 2019 | 06:01 AM
lonesum's Avatar
lonesum
Ouch! Go back to original equipment and don't jump on it.
Old Jan 14, 2019 | 06:07 AM
Stevo1340's Avatar
Stevo1340
it’s never been original
Old Jan 14, 2019 | 07:06 AM
Hey Man's Avatar
Hey Man
Pull the kicker cover and look at the innards. See what might look worn or misaligned and instead of replacing some parts you might consider installing a different kicker set up. I'm not real sure of the quality of the Chrome Specialties kicker.
Old Jan 14, 2019 | 07:15 AM
0maha's Avatar
0maha
Has it ever worked correctly, or is this a new install?
Old Jan 14, 2019 | 07:31 AM
Stevo1340's Avatar
Stevo1340
it works most of the time but spins out when I least expect it!
Old Jan 14, 2019 | 07:36 AM
0maha's Avatar
0maha
I get that, but what I'm asking is if was reliable for a meaningful period of time and only later started acting up, or if it was this way from the start.
Old Jan 14, 2019 | 07:44 AM
TwiZted Biker's Avatar
TwiZted Biker
There's a brass bushing in those cheap kits that wobbles out very quickly that gives the problems you are having, also the extension that goes on the end of the mainshaft that gear rides on has a tendency to strip the threads and allows things to move on you, cover has to come off for a look see anyway. Installed a lot of those kits way back when and most had these issues sooner or later if they were used regular. Only Bakers is rock solid but it isn't cheap.
Old Jan 14, 2019 | 07:48 AM
Stevo1340's Avatar
Stevo1340
it’s always done it
