1995 evo
Old Jun 17, 2019 | 11:00 AM
Bowtiejc's Avatar
Bowtiejc
Default 1995 evo
My 1995 Softail has 28k miles on it . If it sits for a long period of time , when you start it . It has a loud ticking in top end . After it idles for a couple minutes and gets warm it is back
to normal . What would be causing this . Worn lifters , cam or maybe oil pump ?
Old Jun 17, 2019 | 12:45 PM
daven9113's Avatar
daven9113
How long is a long period of time? More than likely your lifters bled down.
Does it happen when you ride it often? If not, then I wouldn't be too worried.
Old Jun 17, 2019 | 12:57 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Lifters..... time for new.. OEM or S&S
Old Jun 17, 2019 | 01:05 PM
daven9113's Avatar
daven9113
I was going to suggest earplugs. Cheaper. :-)
Old Jun 17, 2019 | 01:08 PM
98hotrodfatboy
So are bananas but it's not gonna get better...
Old Jun 18, 2019 | 02:18 PM
Tom84FXST's Avatar
Tom84FXST
If you put bananas in the oil it will get quieter...
Old Jun 18, 2019 | 02:27 PM
RHPAW's Avatar
RHPAW
Got a cam in it? Stock lifters usually only go about 25,000 miles after that.
When I took mine out (long time ago), the needles were falling out of the bearings.
Old Jun 18, 2019 | 04:43 PM
Beemervet's Avatar
Beemervet
Old Jun 18, 2019 | 08:47 PM
RANGER73's Avatar
RANGER73
It's bleeding down, perfectly normal.
Old Jun 18, 2019 | 08:53 PM
TSheff's Avatar
TSheff
Might even see base gasket leaks before it warms up too.
Ride it more often or at least run it. Just like bottom breathers, if you let them sit too long they will puke. Keep oil circulating by riding more often. Lifter are not the only thing that are losing oil/lube.
