In the vid, the doode said to be careful bangin on the stand is not recommended. Not in so many wirds. But the warning was loud and clear it should be approached with a careful wack
Thing about what you are trying to accomplish here... rotate one or the other Crank Half to align with the other... can't very well do that with it sitting on the bench... not very easy anyway... it must be suspended between centers in order to "turn" a wheel on a Shaft.. not turning much at all... but it is turning just the same..
Better than a mallet, I think a high torque ratcheting spreader might be a gentler and more precice method?
A spreader is for a Different process... Rotating one side or the other is for rocking couple, spreading is for vertical alignment...one wheel to another... We simply used a Short bolt with nut on it... let the threads on the bolt do the work...
Most of this process is outlined extremely well in the Shovelhead Service manuals of the day!!!
Course... so is a Valve job...and lots of folks don't get that even close to Correct either!!!!
First off this whole thread and nobody clued yet the 89's a rigid mounted drivetrain and the 98 is rubber mounted, of course felt vibration at varying RPM's is going to feel like a balance issue.
Can you say DUH.....
Originally Posted by Mattbastard
I'm really surprised he smacked the flywheel while it was in the truing stand.
I remember reading instructions from S&S on that stand and it said to mark the flywheel, REMOVE IT from the stand, then depending on where you need to smack it you put one flywheel on a slightly elevated surface and smack the other so it's free to move.
I have the old school Rowe flywheel truing stand and you should never smack the wheels while in the jig, it can damage things. Myself I used to use a old chunk of oak planking to set the wheels on and a babbitt hammer I made to massage them as needed, wood walked off somewhere and I found a block of delrin plastic to replace it, like it better anyway, cleaner and no dust.
There's an art to doing a set of 5 pc wheels and getting them right and I will dial mine down to under .001" when I do them, book say .002" is ok I like as close to zero as I get them.
I also have a complete balancing set up including a pink granite and four decimal place machinist levels to stabilize & square things properly. While the knife edge rollers are the thing now I still like the precision ground parallels. More time consuming but I feel it's more accurate for motors that are going to abused some which mine are. Devils in the details and it takes time but can give you a shovel or evo flywheel set that can go 7000rpm.
LOL
LMK what them 0 and 1 wheels measure when ya open it up after running awhile....BTDT
My Partner was **** like that ... even on the Dragbike, till I showed him that no matter how close it is when assembled...once ya run it {admittedly Run Hard] it ain't there no more... but, it don't move too much after that either...Kinda like spinning the Big end of the S&S supremes... gotta do it once... if yer ever gonna hold 'em...
Different story now...
Oh and wayyy back in post #2 I alluded to the differences in rubbermounted vs Solid... and in fact asked for facts about the MoCo policy on Balancing the EVO Mill...
Tatro mentions that in regards to EVO and TC cranks. Fast forward to 6:20 in the below video.
