Weird stator reading
Old Dec 13, 2019 | 09:08 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Default Weird stator reading
What would cause a stator to only read 2 volts AC?
It's not shorted to ground and the resistance between the legs is good.
Old Dec 13, 2019 | 09:20 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Assuming it is an old two wire single phase system. What is the resistance reading you are getting? Is it possible a few magnets have come lose and gone together or would that make max distruction?
Probably the connection is bad where the leads attach to coils. Reads OK till it tries to push the AC thru.
Old Dec 13, 2019 | 09:34 AM
texashillcountry
Dirt don't hurt
0.3 ohms resistance between the legs.
Old Dec 13, 2019 | 09:39 AM
Racepres's Avatar
Racepres
Good thought on the magnets.. The ohms seem OK for the stator... but... Failures occur of all Kinds...
matters not...gotta come apart anyway...
Double check yer meter...
Old Dec 13, 2019 | 09:43 AM
ShovelEd's Avatar
ShovelEd
At what RPM?
Old Dec 13, 2019 | 09:48 AM
daven9113's Avatar
daven9113
Were you having charging problems; the reason for the check?
Old Dec 13, 2019 | 09:58 AM
texashillcountry
Dirt don't hurt
2 different meters same reading.
Originally Posted by ShovelEd
At what RPM?
Not sure bike doesn't have a tach.
Yep not charging.
Old Dec 13, 2019 | 10:06 AM
98hotrodfatboy's Avatar
98hotrodfatboy
If the magnets have slipped and come together you will not get alternating current on a sine wave therefore it will not put out any AC.... I am more suspect to believe a rotor issue.. This is your 3 phase setup right? And all phases come in at .3 ohm and infinite to ground?
Old Dec 13, 2019 | 11:38 AM
daven9113's Avatar
daven9113
Pull your derby cover and do the smell check. Betting that your stator is grounded, and hopefully you caught it early enough to save the regulator. Good luck.
Old Dec 13, 2019 | 01:20 PM
Dr.Hess's Avatar
Dr.Hess
They can be shorted internally. Or perhaps magnets. In any case, it's coming apart, so just do it.
