Weird stator reading
Old Dec 13, 2019 | 09:53 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Hoginedgewood
is it a Harbor Freight volt meter? Is it charging the battery?
Klein and Fluke meters and no.
Old Dec 13, 2019 | 10:05 PM
texashillcountry
Dirt don't hurt
Originally Posted by bad tappets
Electrical systems are a bit wired sometimes. A bad connection down the line can take out other components. Check everything carefully to make sure some other issues isn’t killing the stator, before you go back to stock.
My 2000 F-350, which I bought new, had the stock alternator for 12 years. Stock died, I went through 3 new alternators in the next 3 years. Found frayed wire, replace alternator, been good for 7 years now.
To be flat honest I haven't been impressed with the Cycle Electric system since I installed it.
Old Dec 14, 2019 | 05:27 AM
98hotrodfatboy's Avatar
98hotrodfatboy
There's not much wiring to a charging system you have your positive to the regulator and regulator to ground and battery to ground and then your connections to the stator that's it, anything beyond that must be a bad battery. A poor ground on your regulator will not allow shunting of voltage to ground or back to the battery creating to much heat to the field.. make sure you have no voltage drop to the regulator... What you read at the battery you should have at the regulator.. identical..
Old Dec 14, 2019 | 06:50 AM
splattttttt's Avatar
splattttttt
Originally Posted by Dr.Hess
They can be shorted internally. Or perhaps magnets. In any case, it's coming apart, so just do it.
all the encouragement he needed to hear LOL
Old Dec 19, 2019 | 03:25 PM
rizzo's Avatar
rizzo
You get 'er fixed Mike?
Old Dec 19, 2019 | 04:55 PM
texashillcountry
Dirt don't hurt
Not yet.
Had to order a plastic connector from Harley today.
Probably won't get it fixed till after Christmas.
Fitterwelder
Electrical/Lighting/Alarm
May 16, 2019 11:52 AM
ScottinAZ
General Topics/Tech Tips
Sep 19, 2018 04:12 AM
HDPursuit
Aug 22, 2018 12:56 PM
AllWeatherRider
Aug 16, 2014 04:47 PM
timberwolfz28
EVO
Jun 25, 2009 09:05 PM
