Float bowl adjustment question
Old May 7, 2020 | 06:04 PM
mike131's Avatar
mike131
Originally Posted by JeMangus
1990 FLTCU. Service manual says set height of top of float to the flange at 0.725 inches. Seems I was way off at original setting, but had no issues in running except it was time for removing 30 years of gunk. I used a tire depth guage to measure, it only has 32nd and ml so I used 18.5 ml to get close to the 0.725 inches. Difficult to measure. Seems my original was around 15 ml. I find it hard to believe it was that far off. You tube says measure with carb at 30 degree angle, I saw none of that in service manual. Is something amiss?
yes you are correct, old cv carbs are the round not square like newer ones and the float adjustment is different the setting for round style is .690-.730
Old May 7, 2020 | 07:44 PM
JeMangus's Avatar
JeMangus
Appreciate the replies and the confirmation I am going about it correct. I'm unsure how accurate I was on measure, so will confirm my setting by using the drain tube method as per previous reply.
Old May 7, 2020 | 08:23 PM
mike131's Avatar
mike131
I have the same carb with round style floats, they are great carbs adjusted and jetted correctly, float set higher will be richer, lower leaner
soarguy
Carburetor Related
Feb 18, 2020 04:50 PM
xungan
General Topics/Tech Tips
11
Jan 18, 2016 09:01 PM
Norrl
Jan 20, 2012 01:27 PM
backnasaddle
Dec 2, 2006 10:20 AM
