Seemed like it was harder on the chain life running a solid sprocket in the shovel than using a comp style. Went thru them fairly often even in a closed system.
The last one I put in at about 90000 miles was a Baker and 16000 miles later it’s still running strong. I personally wouldn’t go to a solid compensator.
I've been running a $99 JP cycles comp on the 111 since '15, I only needed the spring cup and sprocket, whole thing was cheaper.
Just looked at order history, it was # 601-363, searched and it said number not found, figures.
