Chain conversion 1998 fxdl EVO
Old May 30, 2021 | 09:18 PM
98FXDan's Avatar
98FXDan
Stage III
Default Chain conversion 1998 fxdl EVO
I currently have the primary ripped apart on my stock 1998 fxdl. Laconia bike week is in 2 weeks and I don't want to have to take my father's heritage springer. I was replacing a few things in there and had a buddy throw the idea of a chain drive kit. I want to throw my own kit together with a PBI 23t front and a flat bung king 48t rear. I am not sure of the spacing requirements for the rear sprocket or the corresponding offset for the front sprocket. Any suggestions?
Old May 30, 2021 | 10:02 PM
Tee&Vee's Avatar
Tee&Vee
Why offset? Did you go larger rear wheel, wider tire?
if you're in NH then try vulcanworks.net. they have a 4697 part number. I think you may have to do the math and then figure your bike weight, your weight and your riding style. Lots of guys really over-gear their bikes.
Evo engines like to be 3500 rpms range. My experience has been that they thrive at that speed.
good luck!
Old May 31, 2021 | 09:59 AM
98FXDan's Avatar
98FXDan
Stage III
good luck!
so I guess my question would be that if I do not need an offset front sprocket, what size spacer do I need for the flat rear sprocket. The Vulcan kit looks decent but if im spending the money I want top quality parts (pbi front, ARP bolts, ek chain)
Old May 31, 2021 | 12:18 PM
Tee&Vee's Avatar
Tee&Vee
Break it down more fundamentally than your thinking goes.
inner primary off, pulley off; is the transmission any further inboard, outboard?
Rear wheel pulley off, did the hub move too? If it did then what about new spacers?
Tie a string or get a long straight edge. A metal ruler from Lowe's can work here.
What i meant to add is that your answers will come from mock-up. I'm actually not too sure if there is a kit that you can buy that would be 100% reliable on a 22 year old junkbox. Mine is a POS too so no offense meant there!
Old May 31, 2021 | 12:29 PM
IBDAGRIZ's Avatar
IBDAGRIZ
I think I'm running a .50" offset up front on my 94 Ultra. Best way is to mock it up and use a straight edge.
Depends on if you're using a flat rear or a dished one as well as to what you run. I run flat rear ones.
Plan on ditching the lower belt cover as well.
Griz
Old May 31, 2021 | 01:56 PM
Tee&Vee's Avatar
Tee&Vee
After rereading your initial post I think time is not your friend. Honestly, a lot of the things I've changed on this bike I had to buy one then assemble then re-buy then refit then reassemble.....
Unless you're like my wife and buy every combination of sizes of parts then return what you don't use I think you're in for a few days down time
Old Jun 2, 2021 | 08:59 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Why a chain drive? Been there done that... Went back to belt, even on Hi horsepower drive trains..
Old Jun 2, 2021 | 09:42 AM
GBHH's Avatar
GBHH
An engineer was the first to give me the sage advice;
"If it ain't broke, don't fix it"
Old Jun 3, 2021 | 02:45 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Harley dudes, "if it ain't broke, fix it." 😉 😉
randazlr
Feb 8, 2017 04:14 PM
8ntsane
EVO
46
Oct 11, 2016 03:09 PM
homiegfunk53
Aug 23, 2013 04:31 PM
Jimbo Slice
Aug 8, 2013 11:39 PM
Hog Yild
May 15, 2008 07:36 PM
